Created by: Phil Gorman on 30-03-2011 01:56:58 PM Hi,
I'm using the AMX Duet Module but I having problems with the MSG_PROMPT response. It does not appear to be send a id from the Duet Module and so the user can't respond to the promt.
Line 1 (12:48:00):: Command From [41001:1:1]-[MSG_PROMPT-,Extend meeting,Scheduled meeting ends in 5 minutes. Do you want to extend the meeting for 15 minutes?,Yes,No,,,] Line 2 (12:48:05):: Command To [41001:1:1]-[MSG_PROMPT_RESPONSE-,1] Line 3 (12:48:05):: Command From [41001:1:1]-[MSG_PROMPT_RESPONSE-,1]
Can you help?
Phil.
Subject: RE: MSG_PROMPT Response not displaying id. Replied by: Viggo Fredriksen on 31-03-2011 02:32:59 PM Hi Phil,
this seems to be a bug in the Duet module. I've released a new version 1.3.2 addressing this issue; the module can be found here
Subject: RE: MSG_PROMPT Response not displaying id. Replied by: Phil Gorman on 01-04-2011 07:14:12 PM Thanks for this and for the prompt response!
