Markus Schneider
Problem
Where can I get a copy of the default Auto Attendant script that comes with the CUE module (aa.aef). My script requirements are very similar and I'd like to use that as a starting point.
Solution
The aa.aef script itself contains steps that are not supported in any currently released script editor version. The script itself is pretty simple to create by itself. The ask-cue-editor@external.cisco.com alias can help with sample scripts that provide the same functionality but are not exact copies of the aa.aef file. Another option is to use the CUE Editor Express feature in 3.0.1 and later, which can very easily create an auto attendant like the one found in the aa.aef along with simple customizations.
forestmcclain
Hello everyone
I am in need of help programing a 2851 and 2911
I would like to speak with someone knowable with these systems.
I had a guy in another country to help via TeamViewer but he is no longer available help me with my issues.
