This document was generated from CDN thread
Created by: Greg Dowdy on 16-08-2011 01:37:52 PM
I am muddling through a cisco phone app (I am normally the janitor, not a programmer) that will open a connection to the overhead paging system, play an alert tone that changes with the situation, then allows the app instigator to speak after the tone.
I have created a menuing system that allows the user to pick the alert tone, weather alert, hospital code blue, etc.
At that point the connection overhead is opened with:
<%@ Language=JavaScript %>
mydigits="60";
mMessage1="60";
Response.Buffer = true;
Response.ContentType = "text/xml";
Response.Write("<CiscoIPPhoneExecute>\r\n");
Response.Write("<ExecuteItem URL=\"SendDigits:"+mydigits+":1\"/>\r\n");
Response.Write("</CiscoIPPhoneExecute>\r\n");
Response.Flush();
This all works swimmingly. At that point, what is the best way to play the soundfile, or is this even possible? A working code snipet would help.
I set one of the alert tones as a multicast stream on the CM at 239.1.1.1:16384, but am having trouble playing the stream. Can this even be done over the open connection? I read where the port needs to be greater than 20xxx. Is this true?
Is tftp a better method? Help is appreciated.
Subject: RE: Open overhead paging-play sound file -then talk
Replied by: Greg Dowdy on 24-08-2011 04:28:18 PM
mydigits="60";
mMessage1="60";
Response.Flush();
More info:
mywigits="analog1.raw";
mMessage1="chime.raw";
mMessage2="analog2.raw";
serverIP = Request.ServerVariables("LOCAL_ADDR");
Response.Write("<ExecuteItem URL=\"Play:"+mywigits+"\"/>\r\n");
Response.Write("<ExecuteItem URL=\"Play:"+mMessage1+"\"/>\r\n");
Response.Write("<ExecuteItem URL=\"Play:"+mMessage2+"\"/>\r\n");
Response.Flush();
Plays the raw files off the server via tftp, but if you code to dial the number first, the browser loses focus and will not play the raw files.
I am fooling with: Open connection
Delay,
Play file
but not having much luck.
