TCC_2
Level 10
Level 10
Core Issue
The calling party is video enabled (IP phone with Cisco VT Advantage [CVTA]). The calling party and gateway are in different regions, between which the Video Call Bandwidth is set to None.
Resolution
For a workaround, issue the bearer-cap speech command on the voice port.
Note: This command forces the calls to use audio only, which allows the calls to work. This bypasses the bearer capabilities mismatch.
For more information, refer to: Understanding debug isdn q931 Disconnect Cause Codes.
