Core Issue
The resolution discusses a case where the re-order tone is heard before all the digits are dialed. This case applies to both MGCP and H.323 controlled gateways.
Outgoing calls to Public Switched Telephone Network (PSTN) through an H.323 gateway could fail with these symptoms:
For other issues with calls to PSTN or PBX networks through an Media Gateway Control Protocol (MGCP) gateway, refer to the following:
Resolution
To resolve this problem, refer to these options:
- If the calling phone is associated with a Calling Search Space (CSS), and the route pattern that matches the called number is in a partition, ensure that the partition of the route pattern is listed under the calling phone's CSS.
- If the phone's CSS already includes the route pattern's partition as described, reset the CSS and the calling phone. If the failure persists, refer to Setting up Cisco CallManager Traces for the TAC and present them to the Cisco Technical Support Website for further diagnosis.
- If the calling phone is associated with a CSS, but the router pattern that matches the called number is not in a partition, reset the CSSand the calling phone. If the failure persists, refer to Setting up Cisco CallManager Traces for the TAC and present them to Cisco Technical Support Website for further diagnosis.
- If the calling phone is not associated with any CSS, ensure the route pattern that matches the called number is in a partition. If it does, either remove the partition information from the route pattern, or add the partition to a CSS of the calling phone (based on your class of service policies).
- If no CSS or partitions are used, reset the calling phone to ensure the Distinguished Name (DN) is updated in Structured Query Language (SQL) database.
If the above options do not resolve the problem, refer to Troubleshooting Cisco IP Phone-to-Cisco IOS Gateway Calls (4.0 release). For other versions of CallManager, refer to the CallManager Troubleshooting Guides index, select the appropriate troubleshooting guide and navigate to the relevant chapter.
For more information on CSS and partitions, refer to Understanding and Using Partitions and Calling Search Spaces With Cisco CallManager 3.0.
