cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Roland Russwurm on 10-03-2010 01:52:57 PM
we have an application that pushes (using jtapi passthru) a CiscoIPPhoneExecute XML object to popup a text message on the phone. This works fine on all phone models except the 69xx phones. When using internal URIs it seems to work but as soon as I specify any http URL in the ExecuteItem the phone displays XML Error 4 and the response to the push is <CiscoIPPhoneError Number="1"/>
Attached is also a wireshark trace of the problem.
Subject: RE: Problem with ExecuteItem and 69xx phones
Replied by: Anitha V on 11-03-2010 07:13:00 AM
Hi Roland,
It could be a defect. Will investigate and let you know soon.
Thanks and Regards,
Anitha
Replied by: Roland Russwurm on 22-03-2010 02:01:19 PM
Hi Anitha,
could you find anything?
Thanks and Regards,
Stefan
Replied by: Anitha V on 24-03-2010 06:48:29 AM
Hi Roland,
What phone load are you using?
Anitha
Replied by: Roland Russwurm on 24-03-2010 07:34:35 PM
Hi Anitha,
phone load is 9.0.2 - the latest I could download.
Roland
Replied by: David Staudt on 12-05-2010 03:13:18 AM
FYI this was confirmed as a defect and will be resolved in future releases.
