cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: null on 12-03-2003 08:21:11 AM
The error I am getting in VWS seems to be around the xml tag:
We are getting a VWS error when trying to run the HelloWorld on VWS 2.0/Nuance 8.0.
The platform is Tomcat 4.0.6
10,-,LOG,D_INFO,-,2003/03/11 18:06:52.583,rec01,4,10,-,vcommerce.core.util.Debug,234,SOVoiceXMLObject::handleThrowable: Handling throwable: Error loading resource http://lab02:8080/Audium/Server: Parsing error: org.xml.sax.SAXParseException: Value "1.0" is not one of the enumerated values for this attribute. at line 2
10,-,LOG,D_INFO,-,2003/03/11 18:06:52.583,rec01,4,10,-,vcommerce.core.util.Debug,69,EventScope::findHandler: Looking for handler for event error.badfetch
This is the voiceXML that we see [ using IE 6 ]
http://lab02:8080/Audium/Server?audium_application=Chapter1_HelloWorld
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE vxml PUBLIC "-//Nuance/DTD VoiceXML 2.0//EN" "http://voicexml.nuance.com/dtd/nuancevoicexml-2-0.dtd">
<vxml version="2.0" application="/Audium/Server?audium_root=true&#38;amp;calling_into=Chapter1_HelloWorld">
<property name="confidencelevel" value="0.4" />
<var name="audium_initial_audio_group_log" expr="false" />
<form>
<block>
<assign name="audium_vxmlLog" expr="''" />
<assign name="audium_element_start_time_millisecs" expr="new Date().getTime()" />
<goto next="#start" />
</block>
</form>
<form id="start">
<property name="inputmodes" value="dtmf voice" />
<block>
<assign name="audium_vxmlLog" expr="audium_vxmlLog + '|||audio_group$$$' + 'initial_audio_group' + '^^^' + application.getElapsedTime(audium_element_start_time_millisecs)" />
<goto nextitem="audio_fld" />
</block>
<field name="audio_fld" modal="false">
<property name="timeout" value="15ms" />
<grammar mode="dtmf"><![CDATA[></grammar>
<prompt bargein="true">
<audio src="/Audium/audio/helloworld_audio_01.wav"><![CDATA]http://Welcome to our Hello world sample application. You are now ready to develop your own world-class voice applications.]></audio>
</prompt>
<catch event="nomatch">
<submit next="/Audium/Server" method="post" namelist="audio_fld audium_vxmlLog" />
</catch>
<catch event="noinput">
</catch>
<filled>
</filled>
</field>
</form>
</vxml>
Subject: Problem with HelloWorld on VWS 2.0.3 - application document
Replied by: null on 12-03-2003 02:03:31 PM
We noticed that the voiceXML application document seems not to be generated for vxml 2.0.
This is the element in the initial page of the application
<vxml version="2.0" application="/Audium/Server?audium_root=true&#38;amp;calling_into=ZOWTest">
Loading the application vxml gives the following:
http://lab02:8080/Audium/Server?audium_root=true&#38;calling_into=ZOWTest
<?xml version="1.0" encoding="UTF-8" ?>
  • <vxml version="1.0">
  • <form>
  • <block>
<audio src="/Audium/audio/error.wav">I'm sorry, there was a problem with this application. Please call back later. Thank you.</audio>
<exit />
</block>
</form>
</vxml>
How can I change the settings in the application to solve this ?
Subject: RE: Problem with HelloWorld on VWS 2.0.3 - application document
Replied by: null on 12-03-2003 04:28:29 PM
Does the application not run at all, or do you hear something and then an error occurs? Do you hear anything, even the default Audium error message?
The VoiceXML you posted here is correct for a VoiceXML 2.0 compatible browser since it includes version="2.0" in the <vxml> tag. In which circumstances did you see the second VoiceXML page you listed?
Replied by: null on 12-03-2003 04:49:48 PM
We get an initial prompt that is immediately interrupted, and then an error.
The application document is what is causing VWS to throw a bad fetch error.
Replied by: null on 12-03-2003 04:59:05 PM
Does the prompt complete when the error is thrown or does it get interrupted? the test application you are using is the hello world application, do you hear the full audio followed by an error, or does it intterupt the audio file playback?
Also, does the activity log indicate an error in the first element? What is printed in the error log?
Replied by: null on 12-03-2003 06:55:11 PM
1. Audio file playback is interrupted
2. Activity log:
192.168.0.43.1047471207548.1.ZOWTest,03/12/2003 14:13:27,,start,newcall,
192.168.0.43.1047471207548.1.ZOWTest,03/12/2003 14:13:27,,start,ani,NA
192.168.0.43.1047471207548.1.ZOWTest,03/12/2003 14:13:27,,start,areacode,NA
192.168.0.43.1047471207548.1.ZOWTest,03/12/2003 14:13:27,,start,exchange,NA
192.168.0.43.1047471207548.1.ZOWTest,03/12/2003 14:13:27,,start,dnis,NA
192.168.0.43.1047471207548.1.ZOWTest,03/12/2003 14:13:27,,start,iidigits,NA
192.168.0.43.1047471207548.1.ZOWTest,03/12/2003 14:13:27,,start,uui,NA
192.168.0.43.1047471207548.1.ZOWTest,03/12/2003 14:13:27,Audio_01,element,enter,
192.168.0.43.1047471207548.1.ZOWTest,03/12/2003 14:13:27,Audio_01,interaction,audio_group,initial_audio_group
192.168.0.43.1047471207548.1.ZOWTest,03/12/2003 14:13:32,Audio_01,element,exit,done
192.168.0.43.1047471207548.1.ZOWTest,03/12/2003 14:13:32,,end,how,disconnect
192.168.0.43.1047471207548.1.ZOWTest,03/12/2003 14:13:32,,end,result,normal
192.168.0.43.1047471207548.1.ZOWTest,03/12/2003 14:13:32,,end,duration,4
192.168.0.43.1047469872962.0.ZOWTest,03/12/2003 13:51:13,,start,newcall,
192.168.0.43.1047469872962.0.ZOWTest,03/12/2003 13:51:13,,start,ani,NA
192.168.0.43.1047469872962.0.ZOWTest,03/12/2003 13:51:13,,start,areacode,NA
192.168.0.43.1047469872962.0.ZOWTest,03/12/2003 13:51:13,,start,exchange,NA
192.168.0.43.1047469872962.0.ZOWTest,03/12/2003 13:51:13,,start,dnis,NA
192.168.0.43.1047469872962.0.ZOWTest,03/12/2003 13:51:13,,start,iidigits,NA
192.168.0.43.1047469872962.0.ZOWTest,03/12/2003 13:51:13,,start,uui,NA
192.168.0.43.1047469872962.0.ZOWTest,03/12/2003 13:51:13,Audio_01,element,enter,
192.168.0.43.1047469872962.0.ZOWTest,03/12/2003 14:21:08,,end,how,disconnect
192.168.0.43.1047469872962.0.ZOWTest,03/12/2003 14:21:08,,end,result,timeout
192.168.0.43.1047469872962.0.ZOWTest,03/12/2003 14:21:08,,end,duration,1795
Replied by: null on 12-03-2003 08:24:23 PM
Ok, some more questions:
1) Could you try either turning off bargein for the Audio element you are using, or make a call where you know for sure there is no noise on the line?
2) Is an error log generated? I'ts name would begin with "error_log" followed by the date. It appears in the same place as the activity log.
3) Is there an error log in the server's log directory? This would be found in teh AUDIUM_HOME/logs directory.
4) The Voice Web server you are using, is is a hosted server or is it in-house? It is is hosted, can you tell me which hoster is it and whether I can make my own applications and try them out. If it is inhouse, are you using the publically released version of the software? How it is connected to a phone, are you using SIP or dialogic cards? An idea of how the voice browser is set up would be helpful.
5) Would it be possible to include the VWS log for the entire call, not just a segment?
For these tests, please make sure you:
1) Delete or rename the Audium logs so I can see just the logs created for the test phone call (the log you posted showed one call that seemed to work fine and another that encountered the error that had an earlier timestamp than the call that came before it).
2) Restart Tomcat fresh.
3) Make a new phone call. Do not try to view the VoiceXML pages in a web browser.
If possible, attatch to a response any error logs, any actvity logs, the VWS log, and if you can, the Tomcat 'localhost_access_log" for that day found in the logs directory of Tomcat. If possible, zip them up into one archive and post it as a response (we've just added the functionality to include attachments to your posts here, so by the time you have the data, you should be able to post to this forum).
Thanks.
Replied by: null on 13-03-2003 09:10:05 AM
. I added the property - bargein with value false. When I looked at the voicexml that was generated - it had bargein false at global scope, but in the form it was set to on. [ see red below ]
I don't understand why the DTMF grammar is being inserted. As you can see from the project - all I wanted was an Audio element.
2. No error log was generated in the application
3. In the AUDIUM_HOME\logs - there were bad_url messages. I have attached all the logs as logs.zip
4. The Voice Web Server is in house - running VWS 2.0.2, with Nuance 8.0 with SP 0201101, on a Dialogic D/120JCT with Dialogic SR 5.1. The media server machine is a 2 CPU PIII 600 MHZ machine with 1 GB RAM and is running Windows 2000. It is connected to the machine running Tomcat and Audium on a 100BT LAN via a switch.
5. In the attached 12mar03.zip - I have attached the VWS logs, the generated vxml using IE, and the complete application folder for the Audium app.
<vxml version="2.0" application="/Audium/Server?audium_root=true&#38;amp;calling_into=ZOWTest">[/color:0c192112a8] <property name="bargein" value="false" />[/color:0c192112a8] <property name="confidencelevel" value="0.4" />
<form>
<block>
</block>
</form>
<form id="start">
<block>
</block>
<prompt bargein="true">[/color:0c192112a8] <audio src="/Audium/audio/helloworld_audio_01.wav" />
</prompt>
</catch>
</catch>
<filled>
</filled>
</field>
</form>
</vxml>
Replied by: null on 13-03-2003 03:32:25 PM
From the readme
On rare occasions, if an error occurs on the Audium Server not affiliated with
a single application, the VoiceXML error page generated will assume the Pure
VoiceXML 1.0 voice browser. This page could cause a parse error on some voice
browsers (such as Nuance Voice Web Server). As a result, this page itself will
trigger the voice browser's default error page.
What does this mean - and is this what I am getting ?
Replied by: null on 13-03-2003 05:54:48 PM
Ok, I believe I know what the problem is. I was initially distracted by your description of the error. The interruption of the audio, I believe, is just an issue with bargein. The "error" you refer to does not show up during the call in the form of some error message read back to the caller, it exists solely in the VWS logs, right? I was going under the presumption that the error manifested itself during the call.
In short, the error in the VWS logs occurred due to a nuance event being caught in the root document Audium produced that shouldn't be caught at all. What happens is that this event is caught at the end of a call and prompts the Audium Server for a VoiceXML page it has no idea what it is supposed to contain. The response is then a generic VoiceXML page that has no DOCTYPE and uses version 1.0 VoiceXML compliance. This page causes an error to be thrown by VWS which is also caught in the root document, leading to another submit to the Audium Server, another error, etc. This infinite loop's effects can be seen in the call error log where there is a long list of bad_url errors. It can also be seen in the VWS logs as a repeat of thrown errors.
This issue existed in the 3.2 release you have but was fixed in the 3.2.2 release we are currently in beta for. The beta is available now and I am sure we can arrange for you to have access to download it. Once installed, this issue will be resolved. I'll let your sales representative know.
One thing, however, on the topic of bargein. To turn off bargein, you can't set a property, all you need to do is select the audio group in the builder and uncheck the bargein checkbox. Using the property won't work because the VoiceXML that is generated uses the bargein attribute of the <prompt> tag which takes precedence (as can be seen by the VoiceXML you posted).
Looking at the VWS logs, it seems to indicate that bargein did take place, which would explain why the audio was interrupted.
If you turn off bargein by deleting the property you added and setting the prompt group's bargein checkbox, you should hear the entire audio file.
If it does, you may want to check with the voice browser documentation to turn the sensitivity down so that the audio isn't always interrupted. You could also use VoiceXML properties for this too, but a solution where you tweak the sensitivity on the voice browser side is preferable.
Note: About the DTMF grammar, you don't need to worry about it, this is something that Audium does to allow for bargein to an audio group that is the only audio in a VoiceXML page. This is not an error.
