cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Pierpaolo Cazzato on 11-02-2011 09:39:59 AM
here you have a description of the current issue with Tandberg C90  telepresence system.
We are controlling a C90 with a Crestron processor, everything works well except
the custom layouts.
We had set the custom layouts from the CIsco TC Console and it worked well while
the system is working  and selecting layouts automatically but we can't manually select the custom layouts.
We are using the following command:
xCommand Video Layout Assign CallId: 1 OutputId:1  LayoutId: 1\x0D\x0A
TC90 is responding with an error saying the LayoutId is unknown...
Where can we find the Id's of the custom layouts stored in the TC90?
By the way when we use the following commands:
xCommand Video Layout LoadDb Type: Custom\x0D\x0A
xCommand Video Layout LoadDb Type: Default\x0D\x0A
these commands are working well, the TC90 is loading correctly the corresponding Layouts
(default or custom).
So our questions are:
How can we manually select a certain Layout ?
Kind Regards
Pierpaolo Cazzato
Subject: RE: Recall a custom layout on a C90 terminal
Replied by: Viggo Fredriksen on 11-02-2011 09:54:29 AM
Hi Pierpaolo,
  you need to recall the layout family, this is done using the PictureLayoutSet command.
1xCommand Video PictureLayoutSet
2    Target: <local/remote>
3    CallId: <0..65534>
4    LayoutFamily(r): <auto/custom/equal/fullscreen/presentationlargespeaker/presentationsmallspeaker/speaker_full>
5    CustomLayoutName: <S: 0, 128>
For example, assign the custom layout family named My Family locally:
1xCommand Video PictureLayoutSet LayoutFamily: custom CustomLayoutName: "My Family"
  Viggo
