This document was generated from CDN thread
Created by: Arvand Owji on 11-02-2009 10:58:07 PM
Hello guys,
Im trying to use a record element to record some audio from the caller. I tried both "Path" and "Ftp" configuration on that element but no matter what I do, all i get is the audio prompt and as soon as I say something to record, I get this errors.
02/11/2009 15:39:22.395,A VoiceXML error occurred of type "error.badfetch.http.400"
This is the configuration i have with the record element:
Noinput timeout: 5s
Max Noinput: 3
Start With Beep: False
Termination DTMF: True
Keep Recording..: False
Max Recod Time: 180
Final silence: 4s
Filename: test
File Type: wav
File Extension: wav
path: c:\test
Any help on this would be really appriciated.
Subject: RE: Record Element (CVP 4.1 and IOS 12.4(15)T7 )
Replied by: Arvand Owji on 12-02-2009 08:31:44 PM
here is the solution for others that mgiht have the same problem:
Set g711ulaw as the only codec on all dial peers
