cdnadmin
Community Member
This document was generated from CDN thread
Created by: Bruno RIGUET on 16-06-2010 02:40:44 PM
Hello all,
somebody can explain me how to make a sql request with the RIS axl functionnality
(https://IP:8443/realtimeservice/services/RisPort?wsdl)
I try to make an sql request like
select * from licenseinfo
select * from licenseserverinfo
but I must complete the query by a type define in WSDL.
See below my error message:
DEBUG:suds.client:sending to (https://10.35.68.10:8443/realtimeservice/services/RisPort)
message:
<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:ns3="http://www.w3.org/2001/XMLSchema" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns0="http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns1="http://schemas.cisco.com/ast/soap/" xmlns:ns2="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
   <SOAP-ENV:Header/>
   <ns2:Body>
      <ns1:ExecuteCCMSQLStatement>
         <ExecuteSQLInputData xsi:type="ns3:string">10.35.68.10</ExecuteSQLInputData>
         <GetColumns xsi:type="ns1:ArrayOfGetColumns">select * from callmanager</GetColumns>
      </ns1:ExecuteCCMSQLStatement>
   </ns2:Body>
</SOAP-ENV:Envelope>
DEBUG:suds.client:headers = {'SOAPAction': u'"[url=http://schemas.cisco.com/ast/soap/action/#PerfmonPort#ExecuteCCMSQLStatement"']http://schemas.cisco.com/ast/soap/action/#PerfmonPort#ExecuteCCMSQLStatement"', 'Content-Type': 'text/xml; charset=utf-8'}
ERROR:suds.client:<?xml version="1.0" encoding="UTF-8"?>
<document>
      <SOAP-ENV:Header/>
      <ns2:Body>
      </ns2:Body>
</document>
DEBUG:suds.client:http failed:
<?xml version="1.0" encoding="utf-8"?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="[url=http://www.w3.org/2001/XMLSchema-instance"><soapenv:Body><soapenv:Fault><faultcode>soapenv:Server.userException</faultcode><faultstring>org.xml.sax.SAXException]http://www.w3.org/2001/XMLSchema-instance"><soapenv:Body><soapenv:Fault><faultcode>soapenv:Server.userException</faultcode><faultstring>org.xml.sax.SAXException: Found character data inside an array element while deserializing</faultstring><detail><ns1:stackTrace xmlns:ns1="[url=http://xml.apache.org/axis/">org.xml.sax.SAXException]http://xml.apache.org/axis/">org.xml.sax.SAXException: Found character data inside an array element while deserializing
 at org.apache.axis.encoding.ser.ArrayDeserializer.characters(ArrayDeserializer.java:502)
 at org.apache.axis.encoding.DeserializationContext.characters(DeserializationContext.java:966)
 at org.apache.axis.message.SAX2EventRecorder.replay(SAX2EventRecorder.java:177)
 at org.apache.axis.message.MessageElement.publishToHandler(MessageElement.java:1141)
 at org.apache.axis.message.RPCElement.deserialize(RPCElement.java:236)
 at org.apache.axis.message.RPCElement.getParams(RPCElement.java:384)
 at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:81)
 at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
 at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
 at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
 at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
 at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
 at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
 at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
 at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
 at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
 at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
 at sun.reflect.GeneratedMethodAccessor198.invoke(Unknown Source)
 at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
 at java.lang.reflect.Method.invoke(Method.java:585)
 at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:243)
 at java.security.AccessController.doPrivileged(Native Method)
 at javax.security.auth.Subject.doAsPrivileged(Subject.java:517)
 at org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:275)
 at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:161)
 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:245)
 at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:50)
 at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:156)
 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:152)
 at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
 at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
 at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:524)
 at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
 at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
 at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:541)
 at org.apache.catalina.authenticator.SingleSignOn.invoke(SingleSignOn.java:392)
 at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
 at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
 at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869)
 at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664)
 at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
 at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
 at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
 at java.lang.Thread.run(Thread.java:595)
</ns1:stackTrace><ns2:hostname xmlns:ns2="[url=http://xml.apache.org/axis/">CCM1</ns2:hostname></detail></soapenv:Fault></soapenv:Body></soapenv:Envelope]http://xml.apache.org/axis/">CCM1</ns2:hostname></detail></soapenv:Fault></soapenv:Body></soapenv:Envelope>
Tahnks by advance for your responses
