Don't you just hate having to run RTMT in a virtual machine, well here it runs in an app for mac.
I have complied a version for CUCM 14.x ( from a version I got for 11.x )
It works on older versions also.
Here it is https://haffi.is/rtmtmac14.zip
older versions
https://haffi.is/rtmtmac12-5.zip
https://haffi.is/rtmtmac12.zip
Enjoy
rsaeks
Level 3
Level 3
Are there any plans to release an RTMT for v15?
Here is 15.
https://haffi.is/rtmtmac15.zip
Phone_Guy
Frequent Visitor
Frequent Visitor
Hey @Hafthor Hilmarsson O'Connor . Getting the following error with RTMT 15, 12.5 works fine. I'm on Sonoma 14.4.1, any ideas?
Phone_Guy
Frequent Visitor
Frequent Visitor
Disregard, I got it fixed. For anyone else who needs it:
Removed extended attributes from the .app and it works fine now (xattr -cr AppName.app). Thanks!
I was going to post that answer 🙂 good you figured it out.
ccanavan
Visitor
Hi @Hafthor Hilmarsson O'Connor
I am running Sonoma 14.6.1 and I'm getting stuck at the loading page post authentication.  Looks like the app is throwing the following exception:
Exception in thread "SplashThread" java.lang.NoSuchFieldError: clientBuildType
at com.cisco.ccm.serviceability.rtmt.utils.SoapServiceInterface.<clinit>(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at com.cisco.ccm.serviceability.rtmt.plugins.PluginManager.checkLoadersForName(Unknown Source)
at com.cisco.ccm.serviceability.rtmt.plugins.PluginManager.importCache(Unknown Source)
at com.cisco.ccm.serviceability.rtmt.plugins.PluginDownloader.deployPlugins(Unknown Source)
at com.cisco.ccm.serviceability.rtmt.ui.AstApplet.constructModule(Unknown Source)
at com.cisco.ccm.serviceability.rtmt.ui.JRtmtMain.launchModule(Unknown Source)
at com.cisco.ccm.serviceability.rtmt.ui.JRtmtMain.doMeat(Unknown Source)
at com.cisco.ccm.serviceability.rtmt.ui.JRtmtMain$SplashWindow$2.run(Unknown Source)
at java.lang.Thread.run(Thread.java:748)
Any ideas on what's causing this or a fix?
Thanks!
my first guess is old java on the mac ?
ccanavan
Visitor
Tried updating to Zulu17.50+19 (build 17.0.11+9-LTS) same error.
Julio Padilla Cruz
Frequent Visitor
Frequent Visitor
thanks for saving my life as well.
Alexey Leshko
Frequent Visitor
Frequent Visitor
Thank you!
And do you have CCX editor for Mac?
Harold Robinson Bailey
Do you have a version 15 RTMT version?
Thank you
Version 15 for CCX is linux App and works fine in macos. At least last time I checked.
jcarrollccna
Community Member
Hi all - I'm running this but the real time data section doesn't load up for me at all.
Anyone else encountered this?
Try looking at the logs , run the app in console to see the STOUT from it.
i.e.
cd the application and find the exec file and run it there
Example
/Applications/RTMT.APP/Contents/MacOS/RTMT
John Ellis
Is there a 12.6.2 version available by chance?
