cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Denis Moiseenko on 07-12-2011 09:16:59 PM
Hi All!
Could you tell me how to connect to the Tandberg codecs C-series, through  the serial port?
I tried to connect to oure C-20 codec using HyperTerminal with the following settings:
Bits per second: 38400 (default settings for the C-20);
Data bits: 8;
Parity: None;
Stop bits: 1;
Flow control: None;
but it doesn't work!
Did anyone have successful serial port connection to the codecs C-series?
if it's not difficult for could you tell me where I'm wrong.
Thank you in advance
Best regards
Denis
Subject: RE: serial port connection to the codecs C series
Replied by: Johan Randby on 12-12-2011 08:57:52 AM
Hi Denis
How are you connecting to the codec? For the C20 you need a splitter cable which splits the Camera control input to Camera control and Serial. The settings do otherwise look correct.
The other codecs in the C-series have a dedicated Serial port..
BR Johan
Replied by: Denis Moiseenko on 13-12-2011 04:04:39 PM
Hi Johan!
I tried to connect with help of usual cable db9 male-db9 female. One end was connected to serial port on c20 and the second end was conected to com port on my pc.
if I understood right I need special splitter cable in order to connect to c20 codec. In this case where I can get this cable?
and another one question can I connect with help of usual cable db9 male-db9 female to other codecs in the C-series?
BR, Denis
Replied by: John Regan on 13-12-2011 04:57:17 PM
Hi Dennis,
You should be able to purchase the splitter cable from Cisco, currently all I have is the old TANDBERG part number and description;
117727 Diagnostic Y Cable for C20 (both camera and RS-232 control)
I will try and get the Cisco part number for you.
Using a standard RS-232 cable you can connect to the C40, C60, C90 as they have standard serial ports being considered integrator codecs.
John
Replied by: John Regan on 13-12-2011 05:06:20 PM
The Cisco Part number should be CAB-C20-RS232-DBG
John
Replied by: Denis Moiseenko on 13-12-2011 05:17:08 PM
Hi John!
Thank you very much for your explanation and for your help!
BR, Denis
