Robert Thomas
Level 7
Level 7
Abstract.
Please find below a tool to simplify the extraction of SIP Messages of a CUCM Trace. This could be usefull for debugging and troubleshooting purposes. This tool is developed by myself and provided 'AS-IS' with best effort support. Notice this is not funded/supported actively by TAC or any BU. This was initially developed at TAC to expedite trace analysis and resolution however I have decided to extend the audience. There are multiple tools that might follow up this initial release.
Features.
  • Parse SDI Traces to extract all messages related to a Call-ID, or CUCM CI.
  • Generate Summary Graph of SIP Interactions.
  • Indicate Direction of Message, Time and IP Address involved.
  • Fast Lookup speed thorugh regular expressions.
  • GUI and Simple to use.
  • NSI based installer, without admin rights required.
Screenshots
Steps to Use:
  • Install using the intuitive installer found at the download section.
  • Open the Application.
  • From Menu File -> Open Folder, select the folder with the uncompressed traces. The tool will lookup recursively (all folders down) to find files.
  • Input the SIP Call-ID, or CI for the call you want to extract. You have to obtain this before (we have another tool to this comming soon).
  • Click find and wait while files are been parsed.
  • You should get two tab with the summary of the call and the complete message.
Versioning.
                      28/10/2013 -> Beta Release v0.1
Oscar Tames
Awesome tool Robert!
