This document was generated from CDN thread
Created by: null on 07-10-2006 06:15:16 PM
Ability to put "reference" names into objects and elements
Then allocate those later. An example to describe this.
Audio object, designer puts a variable named refence in for prompt or TTS.
In the prompt/tts management area the actual wav file and tts text can be allocated against the variable in the listed table of all prompts/tts for the application.
This is neat as non-programmers can get involved.
Subject: RE: Special property references and resolving later
Replied by: Vance Vagell on 12-10-2006 06:59:23 PM
Hi Karl,
This initially sounds like substitution, could you please provide some additional examples of how this might work? We will gladly add it as a feature request, but would like to make sure we describe it properly, to meet your needs.
Vance
