on 01-24-2014 02:20 PM
Yes, as I replied earlier, irt worked fine. There was a issue with the certificate itself. Got the right cert and it worked fine.
From: Cisco Developer Community Forums [mailto:cdicuser@developer.cisco.com]
Sent: Wednesday, July 20, 2011 5:55 AM
To: cdicuser@developer.cisco.com
Subject: New Message from indumathiIVR (simulated) in Customer Voice Portal (CVP) - CVP - All Versions: RE: SSL issues with CVP 8.0/Tomcat
indumathiIVR (simulated) has created a new message in the forum "CVP - All Versions":
Have you got the solution?
Have you tried setting the system properties for "truststore" and "trustStorePassword"?
Indumathi
To respond to this post, please click the following link:
<http://developer.cisco.com/web/cvp/forums/-/message_boards/view_message/4248230>
or simply reply to this email.
