cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: mark hackett on 08-11-2010 09:52:38 PM
Hey smart people,
Is there a way to get the DVI (PC-VGA) input on a MXP6000 to be one of the "pictures" available for the virtual monitors in a non-h.239/duo call?
I understand that I could use the duo source picture...but that relies on a h.239/duo enabled call. (if you try to use the duo "picture in a non-h.239/duo call you just get local video...main i think)
I don't want to be dependant on the call being h.239/duo in order to use the PC source as a "picture" for virtual monitor layouts.
I want to compose virtual monitor of a split between local/remote/pc-vga-source
Thanks in advance
