cdnadmin
Community Member
This document was generated from CDN thread
Created by: Chrysostomos Christofi on 10-02-2011 09:51:36 AM
Hi to all
I am new with this and i need your help
I have CUCM 7.1.5 connected Voice Gateway via H323
I want to add some .tcl scripts on Voice Gateway
Could you pls give me some instructions for how to do it
Thankikg you in advance
Subject: RE: TCL SCRIPT FOR VOICE GATEWAY
Replied by: Yaw-Ming Chen on 10-02-2011 10:26:19 AM
The information you need is in this tech center where you posted this question.
http://developer.cisco.com/web/vgapi/resources
Also you can consider CDN support services.
http://developer.cisco.com/web/devservices
Thanks !
Replied by: Chrysostomos Christofi on 11-02-2011 09:55:43 AM
Dear Yaw-Ming Chen
Thank you for your reply
But a specific info it would be appreciated much more
Replied by: Yaw-Ming Chen on 11-02-2011 10:15:15 AM
From the following link you can start with programming guide while reading programming guide you can refer to sample Tcl script in the same link.
Thanks !
Replied by: Anusha Kannappan on 15-02-2011 06:43:53 AM
Hi Chrysostomos,
Assuming your phone have been registered to the CUCM and they are in working condition, please use the following steps on the voice gateway to load the script and mapping them to the dial-peer.
Loading the script:
R1#conf t
R1(config)#application
R1(config-app)#service application_name script_url
for example:
R1(config-app)#service newapp tftp://x.x.x.x/voip/test/xyz.tcl
Once the configs are done you can issue the following command to check whether the script has been loaded properly or not.The status should be in the registered state.
R1#sh call app voice newapp
Mapping to the dial-peer:
To invoke your Tcl IVR script to handle a call, you must associate the application configured with an inbound dial peer. To associate your script with an inbound dial peer, enter the following commands in configuration mode:
R1(config)# dial-peer voice number voip
R1(conf-dial-peer)# incoming called-number destination_number
R1(conf-dial-peer)# service application_name
In these commands:
¿number uniquely identifies the dial peer. (This number has local significance only.)
¿destination_number specifies the destination telephone number. Valid entries are any series of digits that specify the E.164 telephone number.
¿application_name is the abbreviated name that you assigned when you loaded the application
for example:
R1(config)# dial-peer voice 3 voip
R1(conf-dial-peer)# incoming called-number 125
R1(conf-dial-peer)# service newapp
Hope this helps you !
Anusha
Replied by: Anusha Kannappan on 15-02-2011 08:20:38 AM
Hi Chrysostomos,
* .tcl script should be loaded on the voice Gateway
* You can use the following in the script directly
media play leg_incoming flash:_goodbye.au
        Make sure the audio file which you are trying to play is copied to the flash as it has been mentioned in the script
* Apart from the registration stuff I don't think there is any other additional steps required on CUCM
X.X.X.X is the tftp address in the below config. Hope you have the voice gateway connected to the tftp server where your scripts and the audio files may reside.
Anusha
Replied by: Anusha Kannappan on 15-02-2011 09:28:42 AM
Hi Chrysostomos,
Yeah the script and the audio prompts can also reside in the flash and from there it could be loaded to the Voice Gateway.
But anyways the media play command has to be used in the script if you want to play the audio file using the TCL-IVR script. Again the location may varry it could the flash or servers.
you can use any one of the way to use the audio files to be played
* service busy-ringback flash:busy-ringback.tcl
  paramspace english location flash:
and in the script you can use the media play command as follows
media play leg_incoming <name of the prompt>
              (or)
* can be used in the script directly
             (or)
  param welcome-prompt <name of the prompt>
and in the script
if [infotag get cfg_avpair_exists welcome-prompt] {
                set welcomePrompt [string trim [infotag get cfg_avpair welcome-prompt]]
        } else {
                set welcomePrompt "<name of the prompt>"
Anusha
Replied by: Chrysostomos Christofi on 15-02-2011 05:01:20 AM
Dear ALL
What i need is a specific instructions how to make the  tcl script to work
I have the  tcl script ready for this requirements.(for example number 1010 call 1257 and the 1257 is already on the phone then , i need there the tcl script to be involved and play one announcement that the 1257 is already on the phone)
What i dont know is the specific procedure that have to be done on Voice Gateway and also to CUCM
With a general links sorry but you dont help us
chrysostomos
Replied by: Chrysostomos Christofi on 15-02-2011 07:41:41 AM
Dear Anusha
Its really a wonderful and useful post
Many Thanks for your help
3 questions
1) i have to upload the .tcl script on voice Gateway or ON CUCM via tftp file management on OS administration page?
2) How i can associate the prompt to play with a Specific tcl script
3) Except phone registration is any other steps that i have to perform on CUCM?
X.X.X.X Is the IP of CUCM? i have to upload script .tcl and prompt to CUCM and then load them from Voice Gateway
Thank you again Anusha for the precious help
Replied by: Chrysostomos Christofi on 15-02-2011 08:41:55 AM
I think i can use the below commands inside of the above?
I will call the script and the prompt from Voice G.,  From flash
paramspace english location flash:the name of the prompt
Are the above correct?
Thanking you in advance
Replied by: Chrysostomos Christofi on 15-02-2011 09:56:55 AM
Your help is very  precious
Thank you again for all
i am very happy to meet person like you
Have nice day
I will check and let you to know
Replied by: Chrysostomos Christofi on 17-02-2011 11:05:05 AM
Dear ANUSHA
I hope that you are ok
I need your advice again
PLs check my below config
Its not working at all
what is wrong from my config
On Voice Gateway
LOGPRIGW# dir
Directory of flash:/
    1  -rw-    50088592  Sep 30 2009 19:10:50 +03:00  c2800nm-spservicesk9-mz.124-22.T3.bin
    2  -rw-        1823  May 15 2006 16:13:42 +03:00  sdmconfig-2811.cfg
    3  -rw-     4734464  May 15 2006 16:14:10 +03:00  sdm.tar
    4  -rw-      833024  May 15 2006 16:14:26 +03:00  es.tar
    5  -rw-     1052160  May 15 2006 16:14:40 +03:00  common.tar
    6  -rw-        1038  May 15 2006 16:14:54 +03:00  home.shtml
    7  -rw-      102400  May 15 2006 16:15:08 +03:00  home.tar
    8  -rw-      491213  May 15 2006 16:15:24 +03:00  128MB.sdf
    9  -rw-       11189  Oct 17 2010 09:04:02 +03:00  17-10-2010
   11  -rw-        8348  Feb 17 2011 17:53:26 +02:00  busy-ringback.tcl
   10  -rw-       23224  Feb 14 2011 15:11:00 +02:00  en_rec_goodbye.au
application
service aa flash:/busy-ringback.tcl
  paramspace english index 1
  paramspace english language en
  param call-retry-timer 15
  param max-time-vm-retry 2
  paramspace english location flash:/
  param max-time-call-retry 600
  param handoff-string aa
dial-peer voice 3000 voip
description **Busy-ring**
service aa
voice-class codec 2
voice-class h323 1
session target ipv4:192.168.1.242
incoming called-number 1256
dtmf-relay h245-alphanumeric
no vad
BELOW IS THE .TCL SCRIPT
busy-ringback.tcl
proc act_Activation { } {
global alertTime
global prefix
global max_timer
global rdn
global ani
global callInfo
infotag set evt_facility_report gtd
if {[infotag get cfg_avpair_exists prefix]} {
  set prefix [infotag get cfg_avpair prefix]
} else {
  puts -nonewline "busy-ringback: no prefix configured"
  call close
  return
if {[infotag get cfg_avpair_exists alert-time]} {
  set alertTime [infotag get cfg_avpair alert-time]
} else {
  set alertTime 60
set rdn [infotag get leg_rdn]
set ani [infotag get leg_ani]
set callInfo(originationNum) $ani
set callInfo(alertTime) $alertTime
puts -nonewline "busy-ringback: ANI $ani RDN $rdn"
set redirCnt [infotag get leg_redirect_cnt]
if {[infotag get cfg_avpair_exists ignore-redir-count]} {
  set redirCnt 1
if {$redirCnt != 1 || $rdn == ""} {
  puts -nonewline "busy-ringback: not first redirection ($redirCnt) or no RDN"
  call close
  return
if {[infotag get cfg_avpair_exists calling-pattern]} {
  if {[regexp [infotag get cfg_avpair calling-pattern] $ani var] == 0} {
   puts -nonewline "busy-ringback: no prompt for caller $ani"
   set callInfo(notifyEvents) "ev_alert ev_proceeding"
   leg setup $prefix$rdn callInfo
   return
leg setupack leg_incoming
leg connect leg_incoming
leg setup $prefix$rdn callInfo leg_incoming
media play leg_incoming flash:/en_rec_goodbye.au
timer start named_timer 20 PROMPT_TIMER
proc actNoSrv_Proceed {} {
leg proceeding leg_incoming
proc actNoSrv_Alert {} {
leg alert leg_incoming
proc actNoSrv_SetupDone {} {
set status [infotag get evt_status]
puts -nonewline "NoSrvSetupDone status $status"
if {$status != "ls_000"} {
  call close
} else {
  connection create leg_incoming leg_outgoing
proc act_Timer {} {
proc act_MediaDone {} {
puts -nonewline "busy-ringback: mediaDone status [infotag get evt_status]"
timer start named_timer 1 X
proc act_Interval {} {
if [infotag get cfg_avpair_exists media-interval] {
  media play leg_incoming [infotag get cfg_avpair media-interval]
proc act_SetupDone {} {
timer stop named_timer PROMPT_TIMER
puts -nonewline "busy-ringback SetupDone status $status"
  playtone leg_incoming tn_disconnect
  timer start named_timer 5 X
  fsm setstate CLOSING
proc act_Cleanup {} {
call close
proc act_Disconnected {} {
global leg
set leg [infotag get evt_legs]
puts -nonewline "busy-ringback leg $leg disconnect cause [infotag get evt_last_disconnect_cause], IEC [infotag get evt_disc_iec], RSI [infotag get evt_disc_rsi]"
  connection destroy con_all
proc act_DestroyDone {} {
global leg
leg disconnect $leg
proc act_TranRequest {} {
global trnTo
global cntID
set trnTo [infotag get evt_transfer_info transferDest]
set cntID [infotag get evt_transfer_info consultID]
puts -nonewline "busy-ringback: transfer request to $trnTo consultID $cntID leg [infotag get evt_legs]"
proc act_TranDestroyDone {} {
global cntID
global trnTo
set callInfo(transferConsultID) $cntID
set callInfo(notifyEvents) "ev_alert ev_proceeding ev_progress ev_transfer_status"
set callInfo(mode) redirect_rotary
leg setup $trnTo callInfo leg_incoming
proc act_TranSetupDone {} {
puts -nonewline "busy-ringback: tranSetupDone status $status leg $leg"
switch $status {
  ls_000 {
  ls_014 {
   leg transferdone leg_outgoing ts_000
  default {
   leg transferdone leg_incoming ts_009
proc act_Generic { } {
set evt [infotag get evt_event]
switch $evt {
  ev_setup_done         -
  ev_collectdigits_done -
  ev_media_done         -
  ev_disconnected       -
  ev_authorize_done     -
  ev_authenticate_done  -
  ev_vxmldialog_done    -
  ev_subscribe_done     -
  ev_unsubscribe_done   -
  ev_unsubscribe_indication {set status [infotag get evt_status]}
  default   { set status "N/A"}
switch $evt {
  ev_authorize_done     -
  ev_leg_timer          -
  ev_digit_end          -
  ev_hookflash          -
  ev_disconnected       -
  ev_disconnect_done    -
  ev_grab               -
  ev_setup_indication   -
  ev_media_done         -
  ev_handoff            -
  ev_returned           -
  ev_setup_done         -
  ev_transfer_request   -
  ev_vxml_dialog_done   -
  ev_vxmldialog_event {set leg [infotag get evt_legs]}
  default   {set leg "N/A"}
puts -nonewline "Event $evt status $status leg $leg"
if {$evt == "ev_feature" } {
  puts -nonewline "Feature type [infotag get evt_feature_type]"
requiredversion 2.0
# State Machine
set fsm(INIT,ev_setup_indication) "act_Activation     CALLING"
set fsm(CALLING,ev_proceeding)  "actNoSrv_Proceed   PROC"
set fsm(PROC,ev_alert)    "actNoSrv_Alert     ALERT"
set fsm(CALLING,ev_named_timer)  "act_Timer          same_state"
set fsm(CALLING,ev_media_done)  "act_MediaDone      same_state"
set fsm(CALLING,ev_named_timer)  "act_Interval  CALLING"
set fsm(ALERT,ev_setup_done)  "actNoSrv_SetupDone CONNECT"
set fsm(CALLING,ev_setup_done)  "act_SetupDone      CONNECT"
set fsm(CONNECT,ev_transfer_request) "act_TranRequest TRANSFER"
set fsm(TRANSFER,ev_destroy_done) "act_TranDestroyDone same_state"
set fsm(TRANSFER,ev_setup_done)  "act_TranSetupDone  CONNECT"
set fsm(CLOSING,ev_named_timer)  "act_Cleanup        same_state"
set fsm(CONNECT,ev_disconnected) "act_Disconnected same_state"
set fsm(CONNECT,ev_destroy_done) "act_DestroyDone same_state"
set fsm(CONNECT,ev_disconnect_done) "act_Cleanup  same_state"
set fsm(any_state,ev_any_event)  "act_Generic        same_state"
fsm define fsm INIT
Replied by: Anusha Kannappan on 18-02-2011 04:03:33 AM
Hi Chrysostomos,
I don't see any issues with your configs. Just let us know what is the issue faced by you. BTW please go through the documents mentioned previously to gain the basic knowledge.
Anusha
Subject: RE: New Message from Anusha Kannappan in Voice Gateway API (VGAPI) - TCL-AP
Replied by: Chrysostomos Christofi on 18-02-2011 05:45:23 AM
Dear Anusha
As we know cisco does not provide any modification like beep tone when you are already in the phone and someone else call you ate the same time..
So The idea for this script and configuration is when internal users or external users call for example  1256 number and this number is already on the phone then the calling number can receive a modification(here we have an announcement that inform the calling number that ) the called number is already on the phone ..and called number for sure can see that someone else calling him
Pls help , I have stacked
From: Cisco Developer Community Forums [mailto:cdicuser@developer.cisco.com]
Sent: Friday, February 18, 2011 11:12 AM
To: cdicuser@developer.cisco.com
Subject: New Message from Anusha Kannappan in Voice Gateway API (VGAPI) - TCL-API: RE: TCL SCRIPT FOR VOICE GATEWAY
Anusha Kannappan has created a new message in the forum "TCL-API":
Hi Chrysostomos,
Anusha
To respond to this post, please click the following link:
<http://developer.cisco.com/web/vgapi/forums/-/message_boards/view_message/3073080>
or simply reply to this email.
Replied by: Raghavendra Gutty Veeranagappa on 18-02-2011 05:57:02 AM
Hi Chrysostomos,
please let us know is your script is picked up by dialing the destination or are you getting any errors with the script if so please send us the logs by enabling following debugs
debug voip app
debug voip ccapi inout
Raghavendra
Subject: RE: New Message from Raghavendra Gutty Veeranagappa in Voice Gateway API (V
Replied by: Chrysostomos Christofi on 18-02-2011 06:33:23 AM
Dear Gutty
I see that if I call 1256 number internally then I don¿t see anything on the debug
Also my question is how the the voice gateway involve in internal calls
Pls check on the attached the debugs
Sent: Friday, February 18, 2011 12:58 PM
Subject: New Message from Raghavendra Gutty Veeranagappa in Voice Gateway API (VGAPI) - TCL-API: RE: TCL SCRIPT FOR VOICE GATEWAY
Raghavendra Gutty Veeranagappa has created a new message in the forum "TCL-API":
Hi Chrysostomos,
debug voip app
Raghavendra
<http://developer.cisco.com/web/vgapi/forums/-/message_boards/view_message/3073330>
Replied by: Raghavendra Gutty Veeranagappa on 21-02-2011 08:16:00 AM
Hi Chrysostomos,
from logs looks like your script is not picked up default script is picked up, please try to configure your script dial-peer 3.
Raghavendra
