Introduction
Deploying a VoIP infrastructure introduces a new set of challenges that do not exist in circuit-switched networks like the PSTN. Some of the common network problems encountered by providers deploying VoIP infrastructure include the following:
  • Delay/latency
  • Jitter
  • Packet loss
  • Voice Activity Detection (VAD)
  • Other issues,
1. Physical layer impairments: Noise, interference in the line, loose connectors, badly terminated punch-down block, and so on
2. Last-mile connection bandwidth: Low-speed connections, oversubscription of circuits resulting in congestion, and so on
3. Network resource overutilization: High CPU and memory utilization on network devices, oversubscription of IP links resulting in congestion, high number of input/output drops under interfaces, lack of QoS for voice, and so on
4. VoIP application issues: Poor software implementation on PC-based soft clients, lack of QoS and prioritization of resources for voice, and so on
All the above factors to be considered and verified while deploying VOIP infrastructure.
What are the common Voice Quality Problems in IP Networks?
The network problems listed above can seriously impact the quality of voice in an IP network. Some of the common voice quality issues experienced by providers include the following:
1. Noise: This is typically any noise on the line introduced by an analog source in addition to the voice signal. Noise will typically leave the conversation intelligible but still far from excellent. Static, hum, crosstalk, and intermittent popping tones are examples where the calling and called parties can understand each other, but with some effort. Some noises are so severe that the voice becomes unintelligible.
2. Voice distortion: This is typically any problem that affects the voice (RTP/media stream) itself.
3. Echoed voice: Echo voice is where the voice signal is repeated on the line. It can be heard at either end of the call, in varying degrees and with many combinations of delay and loss within the echoed signal.
Voice Quality Issues and Root Cause
Voice Quality Issue
Symptom
Root Cause
Absolute silence
This type of silence between speech
can be understood if you have ever
had the experience of not knowing
whether the other person is still there
because there is no sound on the line.
A common cause for this problem is
VAD without comfort noise. To experience
this symptom, the background
noise is usually loud enough for the
silence insertion to be noticeable but
soft enough so that VAD will be
engaged.
Clicking
Clicking is an external sound similar to
a knock that is usually inserted at
intervals.
A common cause is clock slips or other
digital errors on the line.
Crackling
Crackling is an irregular form of very
light static, similar to the sound a fire
makes.
A common cause is poor electrical connections,
in particular poor cable connections.
Other causes are electrical
interference and a defective power
supply on the phone.
Crosstalk
Crosstalk is a familiar concept where
you can hear someone else’s conversation
on the line. Commonly the other
parties cannot hear you. There are also
forms of crosstalk where all parties can
hear each other.
Wires in close proximity, where the
signal of one is induced into the other,
is a common cause of this problem.
Hissing
Hissing is more driven and constant
than static. White noise is a term often
associated with strong hissing. Pink
noise is a less constant hissing noise,
and brown noise is even less constant.
A common cause of hissing is VAD.
When VAD kicks in, comfort noise
packets are introduced into the audio
stream. The hissing sound is caused by
the introduction of comfort noise into
the conversation.
Static
Severe static is an example of static that
in addition to creating background
noise, affects the dial and ring tones
and the voice itself. Another name for
this symptom might be scratchy or
gravel voice.
A common cause is A-law/Mu-law codec
mismatch. A-law is a codec companding
scheme used outside of the United
States, whereas Mu-law is a U.S.-specific
codec companding scheme. This is typically
involved in international calls originating
or terminating in the United
States.
Talker echo
Talker echo is the signal that leaks in
the far-end hybrid and returns to the
sender (talker). The talker hears an
echo of his own voice.
Common causes are
Insufficient loss of the echo signal.
Echo cancellers in the gateway adjacent
to the far-end hybrid not activating.
Acoustic echo caused by the listener’s
phone.
Tunnel voice
Tunnel voice sounds similar to talking
in a tunnel or on a poor-quality
mobile phone car kit.
A common cause is tight echo with
some loss. For example, 10-ms delay and
50 percent loss on the echo signal.
Soft voice
Soft voice is like a low voice that is
hard to hear.
Soft voice is usually caused by too
much attenuation on the signal, possibly
introduced at one of a number of points
in the network such as a voice gateway
when trying to reduce echo.
