Hiteshwar Walia
Community Member
1.  For H.323/MGCP gateways, add bind statement
2.  Ensure IP routing is enabled on the gateway
3.  Verify IP routing between endpoints
4.  Is there a firewall in between the endpoints?
5.  For 911 calls, telco may not send CONNECT on PRI's.  To cut-through audio add voip rtp send-recv
