Introduction
This document discusses how to Troubleshoot  No-way audio/ dead Air Issue for the PSTN Outbound and Inbound Calls.
Problem Description
Outbound and inbound calls are not working - no-way audio. The PSTN Outbound and Inbound Calls are going through and getting connected fine but after that there is nothing heard, No-way audio/dead air issue for the PSTN calls outbound.
Network Scenario
Mobile phone->PSTN -T1 PRI--> MGCP Gateway -->CUCM -- IP Phone
Components
CUCM 8.5.1
MGCP Gateway IOS version 12.1
Resolution
Troubleshooting Procedure
1) The CUCM traces revealed that the call was connected fine and there was no issue found in the sdi/sdl traces.
     CUCM only plays role in the call setup /tear-down of connection but not during conversation.
  • The Inbound and outbound calls have symptoms of dead air.
  • CUCM traces reveal that the call connects all fine and there seems to be loss of audio packets.
  • While testing the call customer didn't notice any change in TX count. It was showing zero while RX count was increasing gradually.
  • Installed the Wireshark tool.
2)  The Gateway isdn debugs below also didn't reveal the root cause. MGCP Gateway Debugs
MGCP  Gateway Debug for Troubleshooting
   Transfer Capability = Speech
                Transfer Mode = Circuit
                 Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                 Exclusive, Channel 1
        Facility i =  0x9F8B0100A10F02014A06072A8648CE1500040A0100
                 Protocol Profile =  Networking Extensions
                 0xA10F02014A06072A8648CE1500040A0100
                Component =  Invoke component
                        Invoke Id = 74
                         Operation = InformationFollowing (calling_name)
                                 Name information in subsequent FACILITY message
        Calling  Party Number i = 0x2183, '9186255864'
                Plan:ISDN,  Type:National
        Called Party Number i = 0x80, '43000'
                 Plan:Unknown, Type:Unknown
000365: *Jan 12 02:58:18.271: ISDN  Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x9FC1
000366: *Jan  12 02:58:18.367: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8  callref  = 0x9FC1
        Progress Ind i = 0x8088 - In-band info or  appropriate now available
000367: *Jan 12 02:58:18.543: ISDN  Se0/0/0:23 Q931: RX <- FACILITY pd = 8  callref = 0x1FC1
         Facility i =  0x9F8B0100A11702014B020100800F4E4F5244414D203630323030202020
                 0xA11702014B020100800F4E4F5244414D203630323030202020
                        Invoke Id =  75
                        Operation = CallingName
                                 Name Presentation Allowed Extended
                                 Name = NORDAM 60200
000368: *Jan 12 02:58:21.255: ISDN Se0/0/0:23  Q931: TX -> CONNECT pd = 8  callref = 0x9FC1
000369: *Jan 12  02:58:21.287: ISDN Se0/0/0:23 Q931: RX <- CONNECT_ACK pd = 8  callref  = 0x1FC1
[Connection to 10.17.2.9 closed by foreign host]
D6506#telnet  10.17.2.9
d3825voice#debug isdn q931
debug isdn q931  is              ON.
d3825voice#term mon
d3825voice#
000405:  *Jan 12 03:08:43.303: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8   callref = 0x0007
        Cause i = 0x8090 - Normal call clearing
000406:  *Jan 12 03:08:43.583: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8   callref = 0x8007
000407: *Jan 12 03:08:43.603: ISDN Se0/0/0:23  Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0007
000408: *Jan  12 03:08:48.355: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref =  0x0008
        Bearer Capability i = 0x8090A2
                 Standard = CCITT
         Channel ID i = 0xA98397
                Exclusive, Channel 23
         Facility i = 0x9F8B0100A116020101020100800E4E574420546573742050686F6E65
                 0xA116020101020100800E4E574420546573742050686F6E65
                        Invoke Id = 1
                                Name  = NWD Test Phone
        Calling Party Number i = 0x0181,  '3165543998'
                Plan:ISDN, Type:Unknown
         Called Party Number i = 0xA0, '6341600'
                 Plan:Unknown, Type:National
000409: *Jan 12 03:08:48.583: ISDN  Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8008
000410:  *Jan 12 03:08:49.683: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8   callref = 0x8008
000411: *Jan 12 03:08:53.031: ISDN  Se0/0/0:23 Q931: RX <- CONNECT pd = 8  callref = 0x8008
000412:  *Jan 12 03:08:53.403: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd =  8  callref = 0x0008
000413: *Jan 12 03:11:26.731: ISDN Se0/0/0:23  Q931: RX <- DISCONNECT pd = 8  callref = 0x8008
000414: *Jan 12 03:11:26.967:  ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x0008
000415:  *Jan 12 03:11:27.031: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd =  8  callref = 0x8008
called number: 316 -6341600
calling  party: 316 554 3998
Then the packet capture was taken  on interface of the MGCP Gateway.
3).  Ping from the Subnet the IP Phone
Ping from the subnet of the ip phone to GW's interface and vice versa wasn't working fine.
Root cause
  1. The MGCP GW was having two interfaces GIG 0/0 and Ethernet GIG 0/1 both in same subnet.
  2. The signaling and media for mgcp was binded to gig 0/0..
  3. It was found that no routing exists between gig 0/0 and the device IP subnet.
  4. The wire-shark trace/packet capture was taken for the outbound calls at BOTH the interfaces of the GWs i.e. Ethernet GIG 0/0 and 0/1.
Solution
All the traffic and signaling was happening through the second interface 0/1 and the below change were made and router was reloaded to get things back to normal:-
MGCP bind media source-interface (interface Ethenet Gig 0/1)
So that binded the MGCP media streaming to the Ethernet GIG interface 0/1
MGCP Interface was wrongly configured and  that is the cause for the issue. Binding the correct source interface ensured that the media streaming got through for the inbound/outbound calls.
Make test calls and ensure the calls are all going through fine and media got through for the inbound/outbound calls.
Related Information
