cdonleyc
Community Member
The Cisco TelePresence Management Suite (Cisco TMS) is a portal for managing and monitoring your video conferencing systems from a single structured overview. Cisco TMS provides centralized control for on-site and remote video systems, and a deployment and scheduling system for your entire video network. This document provides a troubleshooting guide on Cisco TMS components.
Jens Didriksen
Level 9
Level 9
Re point 5, Java requiring authentication.
This can also be fixed by turning off "Enable the next-generation Java Plug-in" found under Java Plug-in in the Advanced tab of the Java Control Panel.
/jens
