TCC_2
Level 10
Level 10
Core Issue
This behavior is seen if you have a device with a shared line that has an extension mobility (EM) profile associated with that device. After you add a call pickup group, it does not work unless the call pickup group is added first and then the rest of the settings are done.
Resolution
Use one of these two workarounds to resolve this issue:
  • Remove the extension mobility and shared line from the phone, add the call pickup group and  then add back the shared line and extension mobility.
  • Add the call pickup group before you add any other settings to the phone.
Refer Adding a Call Pickup Group Number for related information
