Luis Gomez
In this scenario we will see a new message event on a CUC user, we have configured AcceptAndRelay so we will be covering:
> Conversation Manager logs for communication with CUCM
> MTA logs for message delivery
> SMTP logs for interaction with SMTP server
we have enabled and collected the following logs on CUC:
Micro traces   (All Levels)
  •                 CuCsMgr
  •                 Notifier
  •           MTA
  •           SMTP
Macro traces:   (All Levels)
  •           Call Flow Diagnostics
  •           Call Control (MIU) traces
  •           Conversation Traces
  •           Message Tracking Traces
  •           Traces for MWI problems
Test call information:
Caller 1113
Called 1103
Ext 1103 is set to Forward All to VM on CUCM, Voicemail box of 1103 have AcceptAndRelay to email address: “testinglab@crunity.com
CUC process all info sent by CUCM, we can find all this info on line:
11:49:52.106 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuMethods,12,Enter CAvMiuCall::CallInit
11:49:52.107 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,Arbiter,-1,Incoming Call [callerID='1113' callerName='1113' calledID='1103' redirectingID='1103' altRedirectingID='' lastRedirectingID='1103' altLastRedirectingID='' reason=8=FwdUncond lastReason=8=FwdUncond] port=PhoneSystem-CUCM.235-1-001 portsInUse=1 ansPortsFree=19 callGuid=CC659E56D3824349A8B777E4EDAB550E
so, when looking for a new call event we can do a search for "Incoming Call" and look for the line that match all information of calling, called, timestamp etc.
Take a note also of the callGuid, this number will give you the guideline for the entire call, any other call with a different callGuid is a completely different call, this is very useful for a CUC that handles too many calls at the same time, following this callGuid properly there no change to get lost.
Once CUC receive and process this info it runs an "AttemptForward", this is because call was forward to CUC and not a direct call so "Forward Routing Rules" on CUC comes into play.
NOTE: mark the events "Entering conversation" and "Exiting conversation" so you know exactly what the system is doing on that moment.
11:49:52.110 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,16,AttemptForward : CCsCDEConvBase::Run : Entering conversation [AttemptForward] [Src/CsCDEConvBase.cpp:123]
To forward the Call CUC look for the RedirectingID or lastRedirectingID, only one will match, in this case the "Use Last Rather than first..." option is disabled:
11:49:52.110 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,ConvSub,5,GetRedirectingInfo: System.Conversations.UseLastRedirectingNumber = FALSE [Src/PHTransfer.cpp:126]
11:49:52.110 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,ConvSub,4,GetCalledNumber: GetRedirectingInfo() RedirectingID == 1103, return value: 0x00000000 S_OK [Src/AttemptForward.cpp:65]
CUC look user by DTMF, in this stage will look for Users and Call Handlers.
11:49:52.111 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,0,Entering CCsCallSession::GetCallHandlerByDtmfAccessId
11:49:52.111 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,1,aDtmfAccessId = 1103
11:49:52.131 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,1,Looking for subscriber with objectid 9e561fc1-0ff9-4f3c-a932-9148b3099b48 (Src/CsCallSession.cpp 3867)
11:49:52.131 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,1,Found object in session cache of type CCsCallSubscriber (Src/CsCallSession.cpp 3875)
11:49:52.131 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,1,Found subscriber in session cache with uid 9e561fc1-0ff9-4f3c-a932-9148b3099b48 (Src/CsCallSession.cpp 3894)
11:49:52.132 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,18,attrValue = xuser
11:49:52.132 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,18,m_strAccessId = 1103
Now that CUC have found the user it will forward the call to it:
11:49:52.132 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,ConvSub,5,AttemptForward_RunStart: Found called subscriber: {9e561fc1-0ff9-4f3c-a932-9148b3099b48} xuser 1103 [Src/AttemptForward.cpp:756]
Goes out from the "AttemptForward" conversation and goes into the "PHTransfer"
11:49:52.134 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,16,AttemptForward : CCsCDEConvBase::Run : Exiting conversation [AttemptForward] [Src/CsCDEConvBase.cpp:389]
11:49:52.134 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,16,PHTransfer : CCsCDEConvBase::Run : Entering conversation [PHTransfer] [Src/CsCDEConvBase.cpp:123]
You will see a lot of information between these events but unless you are looking for such detailed information this is not relevant for the call.
It transfers the call to the user and now is ready to play the greeting:
11:49:52.152 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,16,PHTransfer : CCsCDEConvBase::Run : Exiting conversation [PHTransfer] [Src/CsCDEConvBase.cpp:389]
11:49:52.152 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,16,PHGreeting : CCsCDEConvBase::Run : Entering conversation [PHGreeting] [Src/CsCDEConvBase.cpp:123]
So far, CUC have received the call invitation from CUCM but haven't answered yet, is in this moment when CUC is ready to take the call and play the greeting that we can see Unity sending a reply back to CUCM to actually answer the call.
These events where CUC is talking and negotiating with CUCM can be tracked with the "MiuSkinny" event:
11:49:52.165 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuMethods,17,Enter CMiuSkinnyLine::Answer
11:49:52.165 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,24,CAvSkinnyCallStatus::SetState New=<Answer Requested> Old=<Wait For Answer Requested> PreviousOld=<Idle>)
We can see CUC sending the "StationOffHookMessage" event:
11:49:52.165 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,13,Send StationOffHookMessage (4 bytes) no data
11:49:52.165 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,24,CAvSkinnyCallStatus::SetState New=<Wait For Connect> Old=<Answer Requested> PreviousOld=<Wait For Answer Requested>)
11:49:52.165 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,22,CAvSkinnyCallStatus::AwaitCompletion: 'CMiuSkinnyLine::Answer' waiting for completion
11:49:52.175 |1384,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,24,MiuSkinnyLine active: original call
11:49:52.178 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,24,CMiuSkinnyCall::RecvCallInfo()
11:49:52.178 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,24,CMiuSkinnyLine::RetrieveCallInfo to MiuCall: reason=FwdUncond lastReason=FwdUncond callerID='1113' callerName='1113' calledID='1103' redirectingID='1103' lastRedirectingID='1103' fwdLastRedirectingID=''
Received the "StationOpenReceiveChannelMessage"
11:49:52.178 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,12,Receive [Header prefix: length=136 version=18] StationOpenReceiveChannelMessage (136 bytes) conferenceID=23339728 passThruPartyID=16777269 millisecondPacketSize=20 compressionType=4=Media_Payload_G711Ulaw64k qualifierIn=[ecValue=0=Media_EchoCancellation_Off codecParamsUnion.g723BitRate=0] callReference=23339728 mRxMediaEncryptionKeyInfo.algorithmID=0=NO_ENCRYPTION mRxMediaEncryptionKeyInfo.keylen=0 mRxMediaEncryptionKeyInfo.saltlen=0 keyData=<not shown> mRxMediaEncryptionKeyInfo.isMKIPresent=0 mRxMediaEncryptionKeyInfo.keyDerivationRate=0 streamPassThroughID=0 associatedStreamID=0 RFC2833PayloadType=0 dtmfType=10 mixingMode=0 partyDirection=0 sourceIpAddr.ipAddrType=0=Ipv4 sourceIpAddr.stationIpAddr=192.168.217.235 sourcePortNumber=4000 requestedIpAddrType=0=ModeIpv4 <4 bytes not parsed>
11:49:52.178 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,12,Processing StationOpenReceiveChannelMessage
We can see also a "MediaOpenCallReference" with a call reference number; this can be matched with CUCM traces to look for this call on CUCM traces if needed.
11:49:52.178 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,12,MediaOpenCallReference=23339728=0x016422d0
11:49:52.178 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,22,CAvSkinnyCallStatus::SignalOpenReceiveChannel
11:49:52.178 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Enter CMiuMedia::StartReceive
11:49:52.178 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Enter CMiuMedia::OpenChannel Channel Type=Primary Audio Channel
11:49:52.179 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Mixer Message send: GY_MSG_OPEN_CHN-32 len=692 msgID=32 confID=0 chnID=0 seqNo=19442 remoteIP.v6=0 remoteIP.addr.v4addr=0.0.0.0  remoteRTPPort=0 remoteRTCPPort=0 eDTMFPayloadType=0 eInitMute=0 vad=1=GY_ON eStream.codecType=0 eStream.frameSize=0 eStream.bitRate=0 eStream.payloadType=0 precedenceTOS=0 ttl=0 localIP.v6=0 localIP.addr.v4addr=0.0.0.0  localRTPPort=0 localRTCPPort=0 inDTMFPayloadType=0 dtmf=0 inInitMute=0 noCodecs=0 enableSrtp=0 inStreamKey(key)= <not shown> inStreamKey(salt)= <not shown> sessionID=0 endpointType=0=GY_EP_TYPE_USER
11:49:52.185 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,13,Audio Stream State: OldState=STREAM_CLOSED, NewState=STREAM_RECEIVE
11:49:52.185 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Start Receive bIPV6=false RemoteAudioIPv4=0.0.0.0 lRemotePort=0 iAudioSendPacketSize=0 iSendDTMFPayload=101 iWaveFormat=0 iMediaQOS=0 strRemoteAudioIP= lRemoteVideoPort=0 bIPV6Video=false iVideoQOS=0 remoteVideoMaxBitRate=0 remoteVideoLevel=0 remoteVideoRTPPalyoad=0 lLocalPort=19956 iReceiveDTMFPayload=101 fEnableRFC2833=false fEnableSRTP=false lLocalVideoPort=0
11:49:52.185 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,MediaPortUsage RTP port=19956 in use by PhoneSystem-CUCM.235-1-001 objectId='589517fd-c7e6-4bc1-9640-daa26d05cf93']
11:49:52.185 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Exit CMiuMedia::StartReceive=0x00000000=S_OK
11:49:52.185 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,19,CSkinnyWrapper::SetRTPPort 19956
11:49:52.185 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,22,CMiuSkinnyLine::RecvStartMediaReceive-Using receive RTP port 19956
11:49:52.185 |22660,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,13,Send StationOpenReceiveChannelAckMessage (36 bytes) orcStatus=0=orcOk ipAddr.ipAddrType=0=Ipv4 ipAddr.stationIpAddr=192.168.10.81 portNumber=19956 passThruPartyID=16777269
11:49:52.297 |30933,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,12,Receive [Header prefix: length=136 version=18] StationStartMediaTransmissionMessage (136 bytes) conferenceID=23339728 passThruPartyID=16777269 remoteIpAddr.ipAddrType=0=Ipv4 remoteIpAddr.stationIpAddr=192.168.217.235 remotePortNumber=24712 millisecondPacketSize=20 compressionType=4=Media_Payload_G711Ulaw64k qualifierOut=[precedenceValue=184 ssValue=0=Media_SilenceSuppression_Off maxFramesPerPacket=0 codecParamsUnion.g723BitRate=0] callReference=23339728 mTxMediaEncryptionKeyInfo.algorithmID=0=NO_ENCRYPTION mTxMediaEncryptionKeyInfo.keylen=0 mTxMediaEncryptionKeyInfo.saltlen=0 keyData=<not shown> mTxMediaEncryptionKeyInfo.isMKIPresent=0 mTxMediaEncryptionKeyInfo.keyDerivationRate=0 streamPassThroughID=0 associatedStreamID=0 RFC2833PayloadType=0
11:49:52.297 |30933,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,12,Processing StationStartMediaTransmissionMessage
11:49:52.297 |30933,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,24,CAvSkinnyCallStatus::SetState New=<Connected> Old=<Wait For Connect> PreviousOld=<Answer Requested>)
11:49:52.320 |30933,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,24,CMiuSkinnyCall::RecvConnected()
11:49:52.320 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuMethods,12,Exit CAvMiuCall::Answer=0x00045B33=S_MIU_CONNECTED
Once call is negotiated, CUC is now is total control of the call and CUCM is out of the picture.
CUC is ready to play the greeting:
11:49:52.338 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,ConvSub,5,GetActiveMessageRule: [Standard] message rule is active [Src/PHGreeting.cpp:3838]
11:49:52.338 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,ConvSub,5,GetActiveMessageRule: Active Greeting :- Type=Standard, PlayWhat=0, Action=4, PlayVideo=2 [Src/PHGreeting.cpp:3868]
11:49:52.338 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,ConvSub,5,SetPlayPromptProps: PlayWhat=0, Greeting Action=4 Phrase=SystemStandard [Src/PHGreeting.cpp:1571]
11:49:52.339 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,ConvSub,5,UpdateMonitorWithGreetingInfo: Playing greeting for Subscriber:  x user, 1103 [Src/PHGreeting.cpp:181]
Notice CUC will play the "Standard Default" greeting for this user, the audio files to open will say "Sorry, 'ObjectPresentation' is not available, please record your message after the tone"
NOTE: in this case the "ObjectPresentation" will be the user Extension so CUC open the audio file for 1103, in some other cases you will see that CUC opens a TTS session (Text To Speech) to read the user's Display name.
11:49:52.339 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,3,(SingleUse.cpp) Script: PHGreeting_ENU.ps (Make) -- SystemStandard
11:49:52.339 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,3,(SingleUse.cpp) Script: PHGreeting_ENU.ps (AddPrompt) -- Sorry
11:49:52.339 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,3,(SingleUse.cpp) Script: PHGreeting_ENU.ps (AddPhrase) -- ObjectPresentation
11:49:52.339 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,3,(SingleUse.cpp) Script: Common_ENU.ps (AddPrompt) -- Extension
11:49:52.340 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,3,(SingleUse.cpp) Script: Common_ENU.ps (AddPrompt) -- 1_Trailing
11:49:52.340 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,3,(SingleUse.cpp) Script: Common_ENU.ps (AddPrompt) -- 0_Trailing
11:49:52.340 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,3,(SingleUse.cpp) Script: Common_ENU.ps (AddPrompt) -- 3_Leading
11:49:52.340 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,3,(SingleUse.cpp) Script: PHGreeting_ENU.ps (AddPrompt) -- NotAvailable
11:49:52.340 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,3,(SingleUse.cpp) Script: PHGreeting_ENU.ps (AddPrompt) -- OkRecordNow
11:49:52.340 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,1,CCsPhrase::Play() :     [11:49:52 AM 07/28/2016] PhraseID - SystemStandard [Src/CsPhrase.cpp:318]
11:49:52.340 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,6,CCsPhrase::ConvertStrFileName() :         Prompt Name - /opt/cisco/connection/share/prompts/ENU/PCM/PHGreet/AvPHGreetENU018.wav [Src/CsPhrase.cpp:1374]
11:49:52.340 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,6,CCsPhrase::ConvertStrFileName() :         Prompt Name - /opt/cisco/connection/share/prompts/ENU/PCM/SkipAndScan/SkipAndScanENU002.wav [Src/CsPhrase.cpp:1374]
11:49:52.340 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,6,CCsPhrase::ConvertStrFileName() :         Prompt Name - /opt/cisco/connection/share/prompts/ENU/PCM/Common/Numbers/AvCommonENU201.wav [Src/CsPhrase.cpp:1374]
11:49:52.340 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,6,CCsPhrase::ConvertStrFileName() :         Prompt Name - /opt/cisco/connection/share/prompts/ENU/PCM/Common/Numbers/AvCommonENU200.wav [Src/CsPhrase.cpp:1374]
11:49:52.340 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,6,CCsPhrase::ConvertStrFileName() :         Prompt Name - /opt/cisco/connection/share/prompts/ENU/PCM/Common/Numbers/AvCommonENU050.wav [Src/CsPhrase.cpp:1374]
11:49:52.340 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,6,CCsPhrase::ConvertStrFileName() :         Prompt Name - /opt/cisco/connection/share/prompts/ENU/PCM/PHGreet/AvPHGreetENU019.wav [Src/CsPhrase.cpp:1374]
11:49:52.340 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,6,CCsPhrase::ConvertStrFileName() :         Prompt Name - /opt/cisco/connection/share/prompts/ENU/PCM/PHGreet/AvPHGreetENU016.wav [Src/CsPhrase.cpp:1374]
11:49:52.340 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,11,[Port PhoneSystem-CUCM.235-1-001] MiuCall Play begin
11:49:52.340 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuMethods,17,Enter CMiuSkinnyLine::Play
When CUC plays the greeting, we need to trace down the events following the "Mixer Message send" events, you can see the .wav file about to be opened and the Mixer sending a "GY_MSG_PLAY_FILE_START-64" to start playing:
11:49:52.405 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,File Name to play-/opt/cisco/connection/share/prompts/ENU/PCM/PHGreet/AvPHGreetENU018.wav
11:49:52.405 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Mixer Message send: GY_MSG_PLAY_FILE_START-64 len=385 msgID=64 confID=0 chnID=49 seqNo=19445 startTimeInFile=0 maxPlayTime=0 isRepeat=0 extraParam=0 language="" contentType="" speed=0=GY_SPEED_NORMAL enableGC=0 targetGCLevel=0 validateFileHdrFmt=1 fileType[0]=0=GY_AUDIO_WAVE_FORMAT_FILE_TYPE nFiles=1
NOTE: if the audio file is too long you will see SCCP keepalives being exchanged with CUCM.
When the audio file finish, the Mixer closes the file and opens the next one:
11:49:53.244 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,CMiuMedia::Play-Playback completed successfully
11:49:53.245 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Mixer Message send: GY_MSG_CLOSE_PLAY_FILE-66 len=20 msgID=66 confID=0 chnID=49 seqNo=19446 bytes_played_in_ms=0 startPosition=0
11:49:53.286 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,File Name to play-/opt/cisco/connection/share/prompts/ENU/PCM/SkipAndScan/SkipAndScanENU002.wav
11:49:53.286 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Mixer Message send: GY_MSG_PLAY_FILE_START-64 len=391 msgID=64 confID=0 chnID=49 seqNo=19447 startTimeInFile=0 maxPlayTime=0 isRepeat=0 extraParam=0 language="" contentType="" speed=0=GY_SPEED_NORMAL enableGC=0 targetGCLevel=0 validateFileHdrFmt=1 fileType[0]=0=GY_AUDIO_WAVE_FORMAT_FILE_TYPE nFiles=1
These events will go back and forward until last audio file and played, then CUC will check for next stage and open a recording instance:
11:50:03.879 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,CMiuMedia::Play-Wait for Final Play Event completed successfully
11:50:03.879 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuMethods,15,[Port PhoneSystem-CUCM.235-1-001] MiuCall Play complete beginPositionMs=0 endPositionMs=10617 playTimeMs=10617
11:50:03.880 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuMethods,17,Enter CMiuSkinnyLine::GatherDigits
11:50:03.880 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,CMiuMedia::Gather-Waiting for Digits
11:50:03.880 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,CMiuMedia::Gather-Returing Digits <>
11:50:03.880 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,ConvSub,5,GatherDigits: No DTMF received [Src/PHGreeting.cpp:2486]
Conversation next state, Message record
11:50:03.881 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,ConvSub,5,TakeAction: Conversation [] taking action [4] for ID []. [Src/PHGreeting.cpp:2180]
11:50:03.962 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,10,CCsStateMachine::Execute : Event is [RecordMsgEvent] [Src/CsStateMachine.cpp:168]
11:50:03.965 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,10,CCsStateMachine::Execute : Next state is [/opt/cisco/connection/share/tui/PHGreeting.cde!RecordMsg] [Src/CsStateMachine.cpp:190]
11:50:03.989 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,13, : CCsSRecord::OnEntry : Calling ICsMiuCall::Record; lMaxRecordTime = 285000 ms, RecMode = 1 [Src/CsSRecord.cpp:404]
11:50:03.989 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuMethods,15,Enter CAvMiuCall::Record
11:50:03.989 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,11,[Port PhoneSystem-CUCM.235-1-001] MiuCall Record beginning.
Once again the Mixer takes place, this time to record the audio so we will see again the "Mixer Message send" event but now with state: GY_MSG_RECORD_FILE
11:50:03.989 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuMethods,17,Enter CMiuSkinnyLine::Record
11:50:03.989 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Enter CMiuMedia::Record lMaxRecordTime=285000 lRecordMode=1 lStartPositionMs=0 fLiveRecord=0
11:50:03.989 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Recording to /var/opt/cisco/connection/spool/AudioStore/WorkStreams/cuc_0f26c1cb-b931-4311-985f-a931b3b38a2b.tmp
11:50:03.989 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,SilenceTimeoutMs: leading=5000 trailing=3000 (0=disabled)
11:50:03.989 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,maximum recording duration = 285000 (ms) (RecordDefaultMaximumLength=1200000 MaxRecordTime=285000
11:50:03.989 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Mixer Message send: GY_MSG_RECORD_FILE-69 len=168 msgID=69 confID=0 chnID=49 seqNo=19463 codec=1=GY_G711u annIncluded=0 enableAGC=1 targetAGCLevel=-26 playFrontBeep=1 recordingOffsetFromBeep=0 isTTYBeep=0 playLiveBeep=0 playEndingWarningBeep=0 recordingOffsetFromEnd=0 removeFrontSilence=1 removeEndingSilence=1 endingSilenceTimeout=3 maxRecordTime=285 silenceTimeout=5 startTimeInFile=0
in this call, ther caller pressed '#' to stop the recording, we can see the DTMF event again with a "MiuSkinny" for StationKeypadButtonMessage  cDigit=#
11:50:09.075 |30944,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,21,CSkinnyWrapper::ProcessData
11:50:09.076 |30944,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,12,Receive [Header prefix: length=16 version=18] StationKeypadButtonMessage (16 bytes) kpButton=15=skpPound lineInstance=1 callReference=23339728
11:50:09.076 |30944,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,12,Processing StationKeypadButtonMessage
11:50:09.076 |30944,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,22,CAvSkinnyCallStatus::SignalKeyPadButton: cDigit=# dwCallReference=23339728
11:50:09.076 |30944,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Enter CMiuMedia::MediaEventHandler
11:50:09.076 |30944,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,CMiuMedia::MediaEventHandler-Digit (#)
Recording is stopped by Mixer:
11:50:09.076 |30944,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,13,Media State: OldState=STATE_RECORD, NewState=STATE_STOPPING
11:50:09.076 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Enter CMiuMedia::StopRecordFile
11:50:09.076 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Mixer Message send: GY_MSG_STOP_RECORD_FILE-70 len=12 msgID=70 confID=0 chnID=49 seqNo=19465
11:50:09.079 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Enter CMiuMedia::CloseRecordFile
11:50:09.079 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Mixer Message send: GY_MSG_CLOSE_RECORD_FILE-71 len=16 msgID=71 confID=0 chnID=49 seqNo=19466 removeEndRecDTMFToneLen=170
Once the recording is stopped and closed we can see the recording Time in Ms, in this case = recordTimeMs=4410
11:50:09.131 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,CMiuMedia::Record-Wait for Final Record Event completed successfully
11:50:09.132 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuMethods,15,[Port PhoneSystem-CUCM.235-1-001] MiuCall Record complete startPositionMs=0 endPositionMs=4410 recordTimeMs=4410
Process the '#' DTMF and send call to next state, Message edit:
11:50:09.137 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,CMiuMedia::Gather-Returing Digits <#>
11:50:09.138 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,10,CCsStateMachine::Execute : Next state is [/opt/cisco/connection/share/tui/PHGreeting.cde!RunEditMsg] [Src/CsStateMachine.cpp:190]
11:50:09.284 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,16,MessageEditing : CCsCDEConvBase::Run : Entering conversation [MessageEditing] [Src/CsCDEConvBase.cpp:123]
11:50:09.285 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,10,CCsStateMachine::Execute : Next state is [/opt/cisco/connection/share/tui/MessageEditing.cde!PlayAfterMessageEditMenu] [Src/CsStateMachine.cpp:190]
Right here CUC will play the option, to send this message press #, to edit, to cancel etc.
11:50:09.286 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,3,(SingleUse.cpp) Script: PHGreeting_ENU.ps (Make) -- PlayAfterMessageEditMenu_Audio
11:50:09.287 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,3,(SingleUse.cpp) Script: PHGreeting_ENU.ps (AddPrompt) -- ToSend
11:50:09.287 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,3,(SingleUse.cpp) Script: PHGreeting_ENU.ps (AddPrompt) -- EditMessageMenu
11:50:09.287 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,3,(SingleUse.cpp) Script: PHGreeting_ENU.ps (AddPrompt) -- ToCancel
11:50:09.326 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,6,CCsPhrase::ConvertStrFileName() :         Prompt Name - /opt/cisco/connection/share/prompts/ENU/PCM/PHGreet/AvPHGreetENU001.wav [Src/CsPhrase.cpp:1374]
11:50:09.326 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,6,CCsPhrase::ConvertStrFileName() :         Prompt Name - /opt/cisco/connection/share/prompts/ENU/PCM/PHGreet/AvPHGreetENU003.wav [Src/CsPhrase.cpp:1374]
11:50:09.326 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,6,CCsPhrase::ConvertStrFileName() :         Prompt Name - /opt/cisco/connection/share/prompts/ENU/PCM/PHGreet/AvPHGreetENU403.wav [Src/CsPhrase.cpp:1374]
11:50:09.326 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuMethods,17,Enter CMiuSkinnyLine::Play
11:50:09.331 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,File Name to play-/opt/cisco/connection/share/prompts/ENU/PCM/PHGreet/AvPHGreetENU001.wav
11:50:09.331 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Mixer Message send: GY_MSG_PLAY_FILE_START-64 len=385 msgID=64 confID=0 chnID=49 seqNo=19467 startTimeInFile=0 maxPlayTime=0 isRepeat=0 extraParam=0 language="" contentType="" speed=0=GY_SPEED_NORMAL enableGC=0 targetGCLevel=0 validateFileHdrFmt=1 fileType[0]=0=GY_AUDIO_WAVE_FORMAT_FILE_TYPE nFiles=1
Once again you will see this Mixer messages going back and forward until all audio files are done but this greetings are stopped by caller again with DTMF "#"
11:50:13.235 |30938,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,21,CSkinnyWrapper::ProcessData
11:50:13.235 |30938,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,12,Receive [Header prefix: length=16 version=18] StationKeypadButtonMessage (16 bytes) kpButton=15=skpPound lineInstance=1 callReference=23339728
11:50:13.235 |30938,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,12,Processing StationKeypadButtonMessage
11:50:13.235 |30938,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,22,CAvSkinnyCallStatus::SignalKeyPadButton: cDigit=# dwCallReference=23339728
11:50:13.235 |30938,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Enter CMiuMedia::MediaEventHandler
11:50:13.235 |30938,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,CMiuMedia::MediaEventHandler-Digit (#)
Stop the audio:
11:50:13.235 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,CMiuMedia::Play-Stop the Playback
11:50:13.235 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Mixer Message send: GY_MSG_STOP_PLAY_FILE-65 len=20 msgID=65 confID=0 chnID=49 seqNo=19470 bytes_played_in_ms=0 startPosition=0
DTMF '#' send call to next state, Edit and send the message:
11:50:13.280 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuMethods,17,Enter CMiuSkinnyLine::GatherDigits
11:50:13.281 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,7,CCsPhrase::Play() : DTMF [#] [Src/CsPhrase.cpp:612]
11:50:13.281 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,10,CCsStateMachine::Execute : Next state is [/opt/cisco/connection/share/tui/MessageEditing.cde!SendMsg] [Src/CsStateMachine.cpp:190]
CUC process this message and add all the information about Date, Caller, Message type, Message ObjectID etc, we can follow this events with the "AddHeader" lines:
11:50:13.313 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CsMalUmss,14,AddHeader(Date: Thu, 28 Jul 2016 17:50:13 +0000
11:50:13.313 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CsMalUmss,14,AddHeader(From: "David Campos, 1113" <vm-yuser1113@unitycuc10.cravvid1.com>)
11:50:13.313 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CsMalUmss,14,AddHeader(To: vm-xuser1103@unitycuc10.cravvid1.com)
11:50:13.317 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CsMalUmss,14,AddHeader(Message-Id: <MAL.87862a17-ad80-4cc2-874b-1da0ef400b8@unitycuc10.cravvid.com>
11:50:13.317 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CsMalUmss,14,AddHeader(X-CiscoUnity-CallerAni: 1113)
11:50:13.317 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CsMalUmss,14,AddHeader(X-CiscoUnity-CallerName: y user, 1113)
11:50:13.317 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CsMalUmss,14,AddHeader(Subject:    Message from y user, 1113 (1113))
11:50:13.317 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CsMalUmss,14,AddHeader(X-CiscoUnity-MessageType: Voice)
11:50:13.318 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CsMalUmss,14,AddHeader(Content-Type: audio/wav; name=VoiceMessage.wav)
11:50:13.318 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CsMalUmss,14,AddHeader(Content-Transfer-Encoding: Base64)
11:50:13.318 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CsMalUmss,14,AddHeader(Content-Disposition: inline; filename=VoiceMessage.wav; voice=Voice-Message)
a very important line to take a note of is the "MAL.<objectID number>@domain", this is the new voicemail message objectID and we will need this number to look for this message on MTA and MailboxSync traces when is needed.
CUC play the audio file of "Message sent":
11:50:13.319 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,10,CCsStateMachine::Execute : Next state is [/opt/cisco/connection/share/tui/MessageEditing.cde!ConfirmSend] [Src/CsStateMachine.cpp:190]
11:50:13.319 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,0, : CCsSPlayPhrase::OnEntry : Beginning play of phrase MessageSent [Src/CsSPlayPhrase.cpp:146]
11:50:13.320 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,3,(SingleUse.cpp) Script: PHGreeting_ENU.ps (Make) -- MessageSent
11:50:13.320 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,PhraseServer,3,(SingleUse.cpp) Script: PHGreeting_ENU.ps (AddPrompt) -- MessageSent
11:50:13.333 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,11,[Port PhoneSystem-CUCM.235-1-001] MiuCall Play begin
11:50:13.333 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,File Name to play-/opt/cisco/connection/share/prompts/ENU/PCM/PHGreet/AvPHGreetENU008.wav
11:50:13.333 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Mixer Message send: GY_MSG_PLAY_FILE_START-64 len=385 msgID=64 confID=0 chnID=49 seqNo=19472 startTimeInFile=0 maxPlayTime=0 isRepeat=0 extraParam=0 language="" contentType="" speed=0=GY_SPEED_NORMAL enableGC=0 targetGCLevel=0 validateFileHdrFmt=1 fileType[0]=0=GY_AUDIO_WAVE_FORMAT_FILE_TYPE nFiles=1
11:50:15.042 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,CMiuMedia::Play-Playback completed successfully
Most of the time our Trace analysis for Conversation will finish here, after the message is successfully sent we will see on this conversation logs where CUC goes out from the "MessageEditing" state:
11:50:15.084 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,16,MessageEditing : CCsCDEConvBase::Run : Exiting conversation [MessageEditing] [Src/CsCDEConvBase.cpp:389]
it goes to a transfer and and send the call to the "Good Bye" Call handler and then close the line and gets Idle again:
11:50:15.084 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,10,CCsStateMachine::Execute : Next state is [/opt/cisco/connection/share/tui/PHGreeting.cde!AfterMsg] [Src/CsStateMachine.cpp:190]
11:50:15.086 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,ConvSub,5,AfterMsg_OnEntry: After Message Action is GoTo [PHTransfer] [Src/PHGreeting.cpp:345]
11:50:15.087 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,16,PHTransfer : CCsCDEConvBase::Run : Entering conversation [PHTransfer] [Src/CsCDEConvBase.cpp:123]
11:50:15.093 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,18,attrValue = Goodbye
11:50:15.137 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,16,PHTransfer : CCsCDEConvBase::Run : Exiting conversation [PHTransfer] [Src/CsCDEConvBase.cpp:389]
11:50:15.137 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,16,PHGreeting : CCsCDEConvBase::Run : Entering conversation [PHGreeting] [Src/CsCDEConvBase.cpp:123]
11:50:15.137 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,18,attrValue = Goodbye
11:50:15.197 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,ConvSub,5,UpdateMonitorWithGreetingInfo: Playing greeting for Call Handler:  Goodbye [Src/PHGreeting.cpp:181]
11:50:15.198 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,11,[Port PhoneSystem-CUCM.235-1-001] MiuCall Play begin
11:50:15.198 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuMethods,17,Enter CMiuSkinnyLine::Play
11:50:15.201 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuIO,12,Mixer Message send: GY_MSG_PLAY_FILE_START-64 len=392 msgID=64 confID=0 chnID=49 seqNo=19474 startTimeInFile=0 maxPlayTime=0 isRepeat=0 extraParam=0 language="" contentType="" speed=0=GY_SPEED_NORMAL enableGC=0 targetGCLevel=0 validateFileHdrFmt=1 fileType[0]=0=GY_AUDIO_WAVE_FORMAT_FILE_TYPE nFiles=1
CUC received a hang up as the caller has left before CUC finished the audio play back:
11:50:15.668 |30662,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,12,Receive [Header prefix: length=20 version=18] StationCloseReceiveChannelMessage (20 bytes) conferenceID=23339728 passThruPartyID=16777269 callReference=23339728
11:50:15.668 |30662,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,12,Processing StationCloseReceiveChannelMessage
11:50:15.703 |30662,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuSkinny,24,CMiuSkinnyCall::RecvHangUp() - (original call)
VM port goes IDLE again to wait for next call event:
11:50:15.767 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,CDE,10,CCsStateMachine::Execute : Next state is [/opt/cisco/connection/share/tui/PHGreeting.cde!DoHangup] [Src/CsStateMachine.cpp:190]
11:50:15.781 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuMethods,12,Enter CAvMiu::GetCall
11:50:15.781 |30679,PhoneSystem-CUCM.235-1-001,CC659E56D3824349A8B777E4EDAB550E,MiuGeneral,16,Begin wait for new call -> threadsWaiting=20
This trace analysis have only the Conversation Manager portion, on MTA (Message Transfer Agent) logs we will see the message being delivered to the user mailbox and/or bringing up the SMTP to forward the message to Exchange via SMTP Relay.
    MTA traces
I've mentioned to take a note of the "MAL.<objectID number>@domain" we got from the Conversation logs when the system is sending the message, well, we will do a search on the MTA looking for this objectID to find this call events.
From Conversation logs, we got:  MAL.87862a17-ad80-4cc2-874b-1da0ef400b8@unitycuc10.cravvid.com so searching for it we will get this line:
11:50:13.324 |18880,,,MTA,14,Thread=MtaMailDelivery-6; class=CsUnityMtaMessageDelivery;Message File=/var/opt/cisco/connection/spool/UmssMtaQueue/5fecf62d-fc61-46ed-a7a1-f808438ec5b0.eml.mta has Rfc822 MessageId=MAL.87862a17-ad80-4cc2-874b-1da0ef400b8@unitycuc10.cravvid.com Sender="y user, 1113" <vm-yuser1113@unitycuc10.cravvid1.com>
We can follow the guideline number 18880, this number is not unique on the MTA logs but is rarely seen twice in the same timestamp so for this event that takes just a couple of milliseconds we can follow this number to see only the events for this call.
You will see CUC looking for the message recipient:
11:50:13.324 |18880,,,MTA,15,Thread=MtaMailDelivery-6; class=CsUnityMtaMessage;validateSenderIsSubscriber: localPart=vm-yuser1113, domainPart=unitycuc10.cravvid1.com, localDomain=unitycuc10.cravvid1.com
11:50:13.339 |18880,,,MTA,15,Thread=MtaMailDelivery-6; class=CsUnityMtaMessage;Number of recipients in the Message=1 (Rfc822 MessageId=MAL.87862a17-ad80-4cc2-874b-1da0ef400b8@unitycuc10.cravvid.com)
11:50:13.339 |18880,,,MTA,15,Thread=MtaMailDelivery-6; class=CsUnityMtaMessage;Resolve Message Recipient: vm-xuser1103@unitycuc10.cravvid1.com ndr reason: success
Then, it will process the action to take; in this case will do "AcceptAndRelay"
11:50:13.361 |18880,,,MTA,15,Thread=MtaMailDelivery-6; class=CsUnityMtaMessageHandlingProperties;voicemail message action=AcceptAndRelay effective=AcceptAndRelay
11:50:13.362 |18880,,,MTA,15,Thread=MtaMailDelivery-6; class=CsUnityMtaMessage;Relay message for 'vm-xuser1103@unitycuc10.cravvid1.com' (subscriber.objectid=9e561fc1-0ff9-4f3c-a932-9148b3099b48) to 'testinglab@CRUnity.com'
This means, CUC will save the message on the local mailbox for this user and will create a copy of it to be sent to the SMTP smart host, looking to be delivered to a final email destination =  'testinglab@CRUnity.com'
11:50:13.371 |18880,,,MTA,15,Thread=MtaMailDelivery-6; class=CsUnityMtaMessage;Relaying to relayaddress='testinglab@CRUnity.com'
Before that, the system processes the local message recipient:
11:50:13.376 |18880,,,MTA,15,Thread=MtaMailDelivery-6; class=CsUnityMtaMessage;Original Recipient #1 of the Message=vm-xuser1103@unitycuc10.cravvid1.com (Rfc822 MessageId=MAL.87862a17-ad80-4cc2-874b-1da0ef400b8@unitycuc10.cravvid.com)
11:50:13.377 |18880,,,MTA,15,Thread=MtaMailDelivery-6; class=CsUnityMtaLocalDelivery;Deliver Message to recipients on Database : UnityMbxDb1 (Rfc822 MessageId=MAL.87862a17-ad80-4cc2-874b-1da0ef400b8@unitycuc10.cravvid.com) Sender : vm-yuser1113@unitycuc10.cravvid1.com
11:50:13.431 |18880,,,MTA,14,Thread=MtaMailDelivery-6; class=CsUnityMtaLocalDelivery;Deliver a message to local recipients
Open the "UnityMbxDb1", this is the Mailstore Database:
11:50:13.676 |18880,,,MTA,15,Thread=MtaMailDelivery-6; class=CsUnityMtaLocalDelivery;Opened connection to UnityMbxDb1
Add the recipient and deliver the message:
11:50:13.700 |18880,,,MTA,15,Thread=MtaMailDelivery-6; class=CsUnityMtaLocalDelivery;Adding recipient for the Message Id:fc317d15-05b7-4dd5-91ac-687ca73df0ad. Recipient Email=vm-xuser1103@unitycuc10.cravvid1.com. Recipient Id=06a9bcb0-9f92-4771-999f-b80383bd3837
11:50:13.771 |18880,,,MTA,14,Thread=MtaMailDelivery-6; class=CsUnityMtaLocalDelivery;Message Delivered to Recipient. SMTP Addreess=vm-xuser1103@unitycuc10.cravvid1.com mailbox Id=06a9bcb0-9f92-4771-999f-b80383bd3837
Close the "UnityMbxDb1"
11:50:13.796 |18880,,,MTA,15,Thread=MtaMailDelivery-6; class=CsUnityMtaLocalDelivery;Closing connection to UnityMbxDb1
For the relay message, it notifies the SMTP so we will see those events on the SMTP traces:
11:50:14.038 |18880,,,MTA,15,Thread=MtaMailDelivery-6; class=CsUnityMtaCreateSmtpRelayMessage;Create STMP Message. File Name=/var/opt/cisco/connection/spool/UmssMtaTemp/CUMTA.0c4b4d24-f3b1-4c68-acc5-f7fb592c2956@UnityCUC10.txt
11:50:14.722 |18880,,,MTA,15,Thread=MtaMailDelivery-6; class=CsUnityMtaForeignOut;!!! Notify SMTP Server !!!
Finished the message delivery and then mark it as successful:
11:50:14.722 |18880,,,MTA,15,Thread=MtaMailDelivery-6; class=CsUnityMtaDelivery;Finish Message Delivery for fileName=/var/opt/cisco/connection/spool/UmssMtaQueue/5fecf62d-fc61-46ed-a7a1-f808438ec5b0.eml.mta Status=0
11:50:14.722 |18880,,,MTA,15,Thread=MtaMailDelivery-6; class=CsUnityMtaMessageHandler;Message delivery Status!! File=/var/opt/cisco/connection/spool/UmssMtaQueue/5fecf62d-fc61-46ed-a7a1-f808438ec5b0.eml.mta; Status=0; retry Count=0 retry limit=3
11:50:14.722 |18880,,,MTA,14,Thread=MtaMailDelivery-6; class=CsUnityMtaMessageHandler;Message Delivered successfully!! File Name=/var/opt/cisco/connection/spool/UmssMtaQueue/5fecf62d-fc61-46ed-a7a1-f808438ec5b0.eml.mta
    SMTP traces
The MTA process has notified the SMTP, so from SMTP logs we will see the message being sent to the smart host.
In this case, the Smart host on CUC is configured as 192.168.217.100 this is an Exchange 2010 server acting as Smart Host.
Once again we can search for the "MAL.<objectID number>@domain" but also we can look for the relay address we found on the MTA = 'testinglab@CRUnity.com'
We can also follow the threat as guideline (in this case 18720 ) for the events of this call in specific.
When sending message, CUC gets connected with SMTP Smart Host on port 25:
11:50:14.725 |18720,,,SMTP,18,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpC_MsgDelivery;Sending message file: /var/opt/cisco/connection/smtp/default/pickup/CUMTA.0c4b4d24-f3b1-4c68-acc5-f7fb592c2956@UnityCUC10.txt to testinglab@CRUnity.com
11:50:14.725 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpC_MsgDelivery;hostAddress: 192.168.217.100, resolved to ip: /192.168.217.100 port: 25
11:50:14.725 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpConnector;Connecting to SMTP server. Remote IP=192.168.217.100 Remote Port=25
11:50:17.732 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpConnector;Connected to SMTP server. Remote IP=192.168.217.100 Remote Port=25 smtpResponseTimeoutSec=14
Once it gets connected, we can identify the CUC messages with "Unity SMTP Client" and the Smart Host messages with "SMTP Server", so basically "Unity SMTP Client" is unity talking and "SMTP Server" is Exchange talking.
11:50:22.740 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpConnector;SMTP Server: 220 WIN-5T7BL13V7G8.CRUnity.com Microsoft ESMTP MAIL Service ready at Thu, 28 Jul 2016 11:43:02 -0700
11:50:22.741 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpConnector;Unity SMTP Client: EHLO UnityCUC10.cravvid.com
11:50:22.742 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpConnector;SMTP Server: 250-WIN-5T7BL13V7G8.CRUnity.com Hello [192.168.10.81]
CUC present the message with FROM and TO, Exchange respond with OK
11:50:22.742 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpConnector;Unity SMTP Client: MAIL FROM:<vm-yuser1113@unitycuc10.cravvid1.com>
11:50:22.743 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpConnector;SMTP Server: 250 2.1.0 Sender OK
Most of the time when there a case reporting this message does not reach the email destination we will see an error here, when CUC present the Recipient the SMTP respond with a "550 5.7.1 Unable to relay" or any other error, this means the SMTP is rejecting the message and the issue needs to be addressed by the Exchange/Smart Host administrator
11:50:22.744 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpConnector;Unity SMTP Client: RCPT TO:<testinglab@CRUnity.com>
11:50:22.744 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpConnector;SMTP Server: 250 2.1.5 Recipient OK
11:50:22.744 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpConnector;Unity SMTP Client: DATA
SMTP here is sending this message to a queue for delivery, CUC complete its part and now the message delivery is in hands of the SMTP smart host.
11:50:22.983 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpConnector;SMTP Server: 250 2.6.0 <MAL.87862a17-ad80-4cc2-874b-1da0ef400b8@unitycuc10.cravvid.com> [InternalId=165] Queued mail for delivery
CUC disconnect and mark the message as successfully delivery:
11:50:22.983 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpConnector;Unity SMTP Client: QUIT
11:50:22.986 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpConnector;SMTP Server: 221 2.0.0 Service closing transmission channel
11:50:22.986 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpC_MsgDelivery;Host Name=192.168.217.100 Message ID=<MAL.87862a17-ad80-4cc2-874b-1da0ef400b8@unitycuc10.cravvid.com> Message delivered to:testinglab@CRUnity.com
11:50:22.986 |18720,,,SMTP,15,Thread=SmtpClient-Delivery-2; class=com.cisco.unity.smtp.client.CsUnitySmtpC_MsgDelivery;Stop: Processing Message. Path=/var/opt/cisco/connection/smtp/default/pickup/CUMTA.0c4b4d24-f3b1-4c68-acc5-f7fb592c2956@UnityCUC10.txt status: completed
As we can see, we can trace down the new voicemail using the "MAL.<objectID number>@domain" on Coversation, MTA and SMPT traces, we can also search on Mailbox Sync traces when Single Inbox is in place, I’ll get also a full trace analysis like this for Unified Messaging to share with you.
I hope you can find this document useful for your CUC trace analysis.
Best regards,
Luis Gomez
luisgom@cisco.com
