cdnadmin
Community Member
This document was generated from CDN thread
Created by: Mohamed Amine KETATA on 11-03-2010 09:34:11 AM
We developed a VXML application that records a message for a caller.
We used the Record_With_Confirm element so that the caller listens to the recorded message before confirming.
We are not using ASR, and we need the confirmation of the caller using the DTMFs.
How this element works? Should the caller press 1 to confirm (instead of Yes) and 2 to reset (instead of No)?
Can someone help us to understand how using the confirmation?
Thanks in advance.
Subject: Re: New Message from Mohamed Amine KETATA in Customer Voice Portal (CVP) -
Replied by: Janine Graves on 11-03-2010 01:29:58 PM
In the audio tab of the Record_with_Confirm element, if you right-click
on AudioGroups, you can add a BeforeConfirm prompt and/or AfterConfirm
prompt. These will be spoken to the caller in conjunction with the
system automatically playing their recording. The system is waiting for
the caller to press 1 to indicate 'Yes' they are confirming the
recording. The element exits down the 'done' path. Or the caller can
press '2' to indicate 'No' they don't like the recording. The element
will allow the caller to leave another recording. Up until the number of
DisconfirmCount number of times.
For example:
                      IVR:  RecordInitial: 'please leave your message
and then press the star key.'
                      <<caller leaves their message and then presses star>>
                      IVR:  BeforeConfirm: 'Please listen to your message'
                      IVR:  << The gateway **automatically** plays the
recorded message >>
                       IVR:  AfterConfirm: 'If you are satisfied, please
press 1 now. To record it again, press 2.
Cisco Developer Community Forums wrote:
> Mohamed Amine KETATA has created a new message in the forum "General
> Discussion - All Versions":
> Hi,
> the DTMFs.
> Thanks in advance.
> To respond to this post, please click the following link:
> <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/2031060>
> or simply reply to this email.
Subject: RE: Re: New Message from Mohamed Amine KETATA in Customer Voice Portal (CVP
Replied by: Mohamed Amine KETATA on 11-03-2010 03:44:09 PM
Hi Janine,
That's exactly what I need.
Thank you very much for your help.
B.R
