cdnadmin
Community Member
This document was generated from CDN thread
Created by: CHRISTIAN END on 16-09-2009 10:03:34 AM
has someone done AXL Requests with VB.NET. I thought that it was not so difficult... But it is "for me"...
I have a Perl script running, doing some things for me. But i want a little graphical interface.
Thanks for the help...
Christian
Subject: RE: VB.NET Example for AXL Requests
Replied by: Dale Eichbauer on 08-10-2009 07:23:39 PM
Here's a VB.Net function I've created that seems to work reasonably well.  I've only run this on V 7.  I have a totally different one for V 4.3.  I'm looking for analog devices in case you are wondering about some of the select parameters.  I pass the IP address, ID, and password.  I've pulled out some proprietary info, but I think it should still work as is.  Hope this helps.
    Public Function Poll_CM(ByVal sServer As String, ByVal sID As String, ByVal sPwd As String) As Integer
        Dim sPost As String
        Dim crlf As String
        Dim iReturnCode As CURLcode
        Dim sOptions As Slist
        Dim easy As Easy
        Dim wf As Easy.WriteFunction
        Dim sf As Easy.SSLContextFunction
        Dim df As Easy.DebugFunction
        Dim sbReturned As System.Text.StringBuilder
        crlf = Chr(13) & Chr(10)
        sbReturned = New System.Text.StringBuilder
        sReturned = ""
        sConsolidated = ""
        bCM7Flag = True
        sPost = "<?xml version=""1.0"" encoding=""UTF-8""?>" & crlf
        sPost = String.Concat(sPost, "<SOAP-ENV:Envelope xmlns:SOAP-ENV=""http://schemas.xmlsoap.org/soap/envelope/"">" & crlf)
        sPost = String.Concat(sPost, "<SOAP-ENV:Body>" & crlf)
        sPost = String.Concat(sPost, "<axlapi:executeSQLQuery xmlns:axlapi=""http://www.cisco.com/AXL/API/1.0"" ")
        sPost = String.Concat(sPost, "xmlns:axl=""http://www.cisco.com/AXL/API/1.0"" ")
        sPost = String.Concat(sPost, "xmlns:xsi=""http://www.w3.org/2001/XMLSchema-instance"" ")
        sPost = String.Concat(sPost, "sequence=""1"" ")
        sPost = String.Concat(sPost, "xsi:schemaLocation=""http://www.cisco.com/AXL/API/1.0 axlsoap.xsd"">" & crlf)
        sPost = String.Concat(sPost, "<sql>SELECT NumPlan.DNOrPattern, NumPlan.AlertingName, Device.Name,Device.Description, (SELECT location.name FROM location WHERE Location.pkid = Device.fkLocation) as LocationName, TypeModel.Name as ModelName, Device.fkEnduser as OwnerKey FROM DeviceNumPlanMap, NumPlan, Device, TypeModel WHERE DeviceNumPlanMap.fkNumPlan=NumPlan.pkid AND DeviceNumPlanMap.fkDevice=Device.pkid AND Device.tkModel = TypeModel.Enum AND (Device.tkModel ='10' OR Device.tkModel = '12' OR Device.tkModel = '30027') ORDER BY Device.Name</sql>" & crlf)
        sPost = String.Concat(sPost, sPost & "</axlapi:executeSQLQuery>" & crlf)
        sPost = String.Concat(sPost, "</SOAP-ENV:Body>" & crlf)
        sPost = String.Concat(sPost, "</SOAP-ENV:Envelope>" & crlf)
        Try
            Curl.GlobalInit(CURLinitFlag.CURL_GLOBAL_ALL)
            Easy = New Easy
            ' Set up write delegate
            wf = New Easy.WriteFunction(AddressOf OnWriteData)
            ' and the SSL delegate
            sf = New Easy.SSLContextFunction(AddressOf OnSSLContext)
            ' and the rest of the cURL options
            easy.SetOpt(CURLoption.CURLOPT_URL, "https://" & sServer & ":8443/axl/")
            easy.SetOpt(CURLoption.CURLOPT_WRITEFUNCTION, wf)
            easy.SetOpt(CURLoption.CURLOPT_CAINFO, Environment.SystemDirectory & "\ca-bundle.crt")
            easy.SetOpt(CURLoption.CURLOPT_USERPWD, sID & ":" & sPwd)
            easy.SetOpt(CURLoption.CURLOPT_SSL_VERIFYPEER, False)   ' don't check the server's certificate
            easy.SetOpt(CURLoption.CURLOPT_SSL_VERIFYHOST, 1)   ' check for existence of certificate but not hostname match
            easy.SetOpt(CURLoption.CURLOPT_POSTFIELDS, sPost)
            sOptions = New Slist
            sOptions.Append("Content-type: text/xml;")  ' one element list so far.  repeat append to add any others
            easy.SetOpt(CURLoption.CURLOPT_HTTPHEADER, sOptions)
            df = New Easy.DebugFunction(AddressOf OnDebug)
            ' easy.SetOpt(CURLoption.CURLOPT_DEBUGFUNCTION, df)     ' turn this and next one on for debugging
            ' easy.SetOpt(CURLoption.CURLOPT_VERBOSE, True)
            iReturnCode = easy.Perform()
            easy.Cleanup()
            Curl.GlobalCleanup()
            easy = Nothing
            wf = Nothing
            sf = Nothing
            sOptions = Nothing
            df = Nothing
            iValidStart = InStr(sReturned, "<return>")
            iValidEnd = InStr(sReturned, "</axl:executeSQLQueryResponse>")
            If (iValidStart > 0) And (iValidEnd > 0) Then
                sReturned = Mid(sReturned, iValidStart, iValidEnd - iValidStart)
                 easy = Nothing
                wf = Nothing
                sf = Nothing
                sOptions = Nothing
                df = Nothing
                sbReturned = Nothing
                Return 0
            Else
                sReturned = " "
                MsgBox("Invalid Data returned from server")
                easy = Nothing
                wf = Nothing
                sf = Nothing
                sOptions = Nothing
                df = Nothing
                Return 999
            End If
        Catch ex As Exception
            MsgBox(ex.ToString())
            easy = Nothing
            wf = Nothing
            sf = Nothing
            sOptions = Nothing
            df = Nothing
            Return 999
        End Try
End Function
Replied by: CHRISTIAN END on 21-10-2009 09:43:58 PM
Hello Dale,
thank you for the reply. I tried the function for me. But i didn't get it running...
What did you use for the IMPORTS in vb.net?
And there are some undeclared vars in the function...
It is possible that i use it wrong... I created a new Form in Visual Studio and have pasted the code into the form.
Or have functions to be used in other ways in vb.net?
Sorry for this simple questions, but my knowledge in vb.net is not so much...
Thanks a lot...
Christian
Replied by: Wai Ming Yap on 27-11-2009 02:09:03 AM
Hi Dale,
I'm new to this as well. I tried your program but it iValidStart=0 and iValidEnd=0.
Seems as though it has returned nothing.
Would it be possible for you to send me a copy of your program and I have a look at it to see what I have missed out?
Thanks.
Wai Ming
