cdnadmin
Community Member
This document was generated from CDN thread
Created by: Grant Bagdasarian on 24-05-2012 02:17:25 AM
Is it possible to set the time a vxml dialog may last? For instance, automatically disconnect the call after 1 minute.
Grant
Subject: RE: Vxml dialog max time
Replied by: Anusha Kannappan on 05-06-2012 06:17:00 AM
Hi Grant,
There is no event timer in VXML API.
Anusha
Replied by: Grant Bagdasarian on 11-06-2012 09:42:51 AM
Hello Anusha,
That's too bad.
It there perhaps another way to control this? I could transform the VXML to TCL to control it, but I rather not.
Grant
Replied by: Raghavendra Gutty Veeranagappa on 13-06-2012 06:39:49 AM
Hi Grant,
did you try using maxtime attribute in transfer to limit the call duration.
<transfer name="mycall" destexpr="'tel: '+ phone_num" bridge="true" connecttimeout="150s" maxtime="180s" cisco-longpound ="true" >
Raghavendra
Replied by: Grant Bagdasarian on 19-06-2012 02:09:34 AM
Hello Raghavendra,
Sorry for my late reply.
It needs to be the max-time for the whole VXML dialog. I'm simply playing an audio file to the end-user, but they're able to repeat it infinite times.
I guess I'll just limit the maximum of repeats to a limited number and disconnect when that number has been reached.
What I'm concerned for is that the end-user doesn't disconnect for some reason and the call stays open. A max-time attribute on the whole vxml would have prevented this and the call would just get disconnected after a certain period of time.
Grant
