TCC_2
Level 10
Level 10
Core Issuess.
In the Cisco Unity Express 2.3 and Cisco CallManager Express 3.3, local phones can call voicemail and the auto attendant, but phones connected over the VPN receive no audio. They connect to voicemail, and the connected time increments, but there is no sound. These VPN phones can make calls to other phones. Also, IP Phones can be pinged from Cisco Unity Express.
Resolution
If an ephone is attached to Cisco CallManager Express over IPsec, the ephone is able to transmit Real-Time Protocol (RTP) over the dialpeer. But, traffic that comes from the dialpeer to the ephone is not encrypted. As a result, the downstream router discards the clear rtp packets. This problem is most commonly seen if encrypted ephones and a Cisco Unity Express module are used together. The problem was found during testing of a teleworker solution.
There are two workarounds:
    • Use encrypted Generic Routing Encapsulation (GRE) tunnels. If the remote router is attached with a GRE/IPsec tunnel, the ephone routes through the tunnel and the GRE interface passes through encryption properly.
    • Use policy based routing (PBR) in order to force the ephone traffic through the encryptor. In order to do this, place a static route to the home ephone that points at a loopback interface. Then, use PBR on the loopback in order to set the next hop downstream of the crypto map. This is an example:
      interface loopback 2
      ip address x.x.x.x 255.255.255.0
      !--- This is the Loopback Interface.
      ip policy route-map policymap
      exit
      ip route x.x.x.x 0.0.0.0 loop 2
      !--- This is the IP Phone Address.
      route-map policymap permit 10
      set ip next-hop y.y.y.y
      !--- This is the Next Hop - Public IP Address.
      exit
    Problem Type
    Call connection  (Connection quality: One-way audio, no busy tone, dropped calls, etc.)
    Voicemail problems
    Call Connection
    One-way audio
    Voicemail System
    Unity express
    Call Topology and Direction
    IP network > PSTN/PBX/gateway
    IP network > PSTN/PBX/gateway > IP network
    Security Features
    Virtual Private Network (VPN)
