James Schiavone
The low level design (LLD) is the basic blueprint for deploying the solution in production. It should provide enough detail so that anyone with a fundamental knowledge of the products can follow the LLD and configure the systems properly.
qamrul2001
Community Member
hi,
We are going to deploy network infrastructure by Cisco Switches & Routers. So I need LLD template.
