TCC_2
Level 10
Level 10
Core Issue
For every issue that causes a phone to reset or restart, Cisco CallManager logs an error in the Application Event Viewer, as shown:
  Event Type: Error
  Event Source: Cisco CallManager
  Event Category: None
  Event ID: 3
  Date: 1/6/2004
  Time: 3:10:17 PM
  User: N/A
  Computer:
  Description:
  Error: DeviceUnregistered - Device unregistered.
  Device name.:
  Device IP address.:
  Device type. [Optional]: 7
  Device description [Optional].: Auto 2002
  Reason Code [Optional].: 9
  App ID: Cisco CallManager
  Cluster ID: CRBNPUB-Cluster
  Node ID:
  Explanation: A device that has previously registered with Cisco CallManager
  has unregistered. This event may be issued as part of normal unregistration
  event or due to some other reason such as loss of keepalives.
  Recommended Action: No action is required if unregistration of this
  device was expected.>
This message is a result of IP phone reset or restart. These are the possible reasons:
  • EM login/logout
  • Admin reset or restart (An administrator resetting the IP phone through the    admin interface)
Resolution
In the message from the Application Event Viewer, Device    type 7 indicates a Cisco 79xx series phone. Reason code    9 is CallManagerReset. Reason Code 9 is a normal condition.
Device reset is typically done with this sequence:
  1. The device unregisters from Cisco CallManager.
    At this time, the DeviceUnregistered event is generated. The reason    code indicates why the device is unregistered. Reason code 9 indicates    it is due to the device reset.
    The DeviceUnregistered event is for all devices that register to Cisco CallManager, including Media Gateway Control Protocol (MGCP), gateways, phones, H.323 trunks, and media devices.
  2. The device re-registers to Cisco CallManager. At this time, the DeviceRegistered event is generated.
Note: There is no guarantee that the device will re-register.
This issue is also documented in Cisco bug ID CSCed38302.
For related information, refer to System Error Messages for Cisco CallManager 3.2.
Problem Type
Call connection  (Connection quality: One-way audio, no busy tone, dropped calls, etc.)
IP phones and other clients  (Client registration, faulty IP phone, etc.)
Call Control
CallManager
CallManager Features
Bad operational behavior, status,information, performance, delay or other CCM failure
IP Phones and Clients
IP phone faulty operation
Registration problems
Failure Type
Crash, reset, failover, etc.
Error message
Frequency and Scope of Symptom
Occurs only during or after a specific event
When Problem Occurs
After reboot
End Where Problem is Heard or Device Type Involved
IP phone
Troubleshooting Tools
Application event viewer or other event log
CallManager Errors
Registration errors
MGCP Features
MGCP gateway
CallManager Versions
CallManager 4.0
CallManager 4.1
CallManager 3.0
CallManager 3.1
CallManager 3.2
CallManager 3.3
IP Phone Models
7900 Series IP Phone
