This document was generated from CDN thread
Created by: Steven Amos on 24-07-2012 11:29:24 AM
I am having some issues getting the VL commands to work correctly. I am calling into a Codian MCU and then setting up my virtual monitors with my AMX code to show the presintation on my left monitors and my remote main on my right monitorseverything works except my presintaton source shows up as a black image no matter what I do.
here is my code to setup my monitors. I have four monitors in the room and am trying to setup my virtual monitors on all four
send_command vdvVTC1, "'INPUT-SDI,2'"
send_command vdvVTC2, "'INPUT-SDI,1'"
on[vdvVTC1,309]//turn on presensation
send_command vdvVTC1, "'VL_ADD-StudentLeft'"
send_command vdvVTC1, "'VL_FRAME_ADD-','StudentLeft',',FS,0,0,10000,10000,1,0,','presination'"
send_command vdvVTC1, "'VL_LOCAL_ASSIGN-','StudentLeft',',',itoa(1)"
wait 10
send_command vdvVTC1, "'VL_ADD-StudentRight'"
send_command vdvVTC1, "'VL_FRAME_ADD-','StudentRight',',FS,0,0,10000,10000,1,0,','remoteMain',',',itoa(1)"
send_command vdvVTC1, "'VL_LOCAL_ASSIGN-','StudentRight',',',itoa(2)"
wait 20
send_command vdvVTC1, "'VL_ADD-TeacherLeft'"
send_command vdvVTC1, "'VL_FRAME_ADD-','TeacherLeft',',FS,0,0,10000,10000,1,0,','presination'"
send_command vdvVTC1, "'VL_LOCAL_ASSIGN-','TeacherLeft',',',itoa(3)"
wait 30
send_command vdvVTC1, "'VL_ADD-TeacherRight'"
send_command vdvVTC1, "'VL_FRAME_ADD-','TeacherRight',',FS,0,0,10000,10000,1,0,','remoteMain',',',itoa(1)"
send_command vdvVTC1, "'VL_LOCAL_ASSIGN-','TeacherRight',',',itoa(4)"
This all works great except the presintation part. I have opened the web interface to my MCU. I see a snapshot of my presentation source in my conference so I know the presentation source is getting to the bridge.
