12-16-2013 05:38 AM - edited 03-12-2019 10:06 AM
Please see the logs------------------------------------------
Dec 16 15:30:48.224: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x47C1C910,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
*Dec 16 15:30:48.224: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=6
*Dec 16 15:30:48.224: //-1/DF5272B38CF7/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4A427754; count=1
*Dec 16 15:30:48.232: //-1/DF5272B38CF7/RXRULE/regxrule_stack_push_RegXruleNumInfo: stack=0x4A427754; count=0
*Dec 16 15:30:48.232: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=4600, Called Number=4600, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=4600
Result=Success(0) after DP_MATCH_DEST
*Dec 16 15:30:48.236: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=2
*Dec 16 15:30:48.236: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=4600, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2
*Dec 16 15:30:48.236: //-1/DF5272B38CF7/DPM/dpMatchPeersCore:
Calling Number=, Called Number=4600, Peer Info Type=DIALPEER_INFO_SPEECH
*Dec 16 15:30:48.236: //-1/DF5272B38CF7/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=2
*Dec 16 15:30:48.236: //-1/DF5272B38CF7/RXRULE/regxrule_stack_push_RegXruleNumInfo: stack=0x4A427754; count=1
*Dec 16 15:30:48.236: //-1/DF5272B38CF7/RXRULE/regxrule_dp_translate: No profile found in peer 2 for outgoing direction
*Dec 16 15:30:48.236: //-1/DF5272B38CF7/RXRULE/regxrule_dp_translate: calling_number= calling_octet=0x0
called_number=4600 called_octet=0x80
redirect_number= redirect_type=0 redirect_plan=0 redirect_PI=0 redirect_SI=0
*Dec 16 15:30:48.240: //-1/DF5272B38CF7/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4A427754; count=2
*Dec 16 15:30:48.240: //-1/DF5272B38CF7/RXRULE/regxrule_stack_push_RegXruleNumInfo: stack=0x4A427754; count=1
*Dec 16 15:30:48.244: //-1/DF5272B38CF7/RXRULE/regxrule_stack_push_RegXruleNumInfo: stack=0x4A427754; count=1
India2811(config)#
*Dec 16 15:30:54.228: //-1/DF5272B38CF7/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4A427754; count=2
Running-config----------------
version 12.4
service password-encryption
service internal
hostname India2811
boot-start-marker
boot system flash:c2800nm-adventerprisek9_ivs-mz.124-15.T1.bin
boot-end-marker
logging buffered 10000000
enable secret 5 $1$hf9n$vE3P5wXUeaDPcxymFQU7/0
enable password 7 01120C0D4F2B5756791A
no aaa new-model
ip cef
no ip domain lookup
trunk group 1
voice-card 0
no dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
address-hiding
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
sip
bind control source-interface FastEthernet0/1
bind media source-interface FastEthernet0/1
header-passing
registrar server expires max 3600 min 3600
no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice translation-rule 1
rule 1 /^023392030/ /5678/
voice translation-rule 2
rule 1 /^.*/ /9&/ type national national
rule 2 /^.*/ /91&/ type national national
rule 3 /^.*/ /9011&/ type international international
voice translation-rule 3
rule 1 /^5.../ /023392030/
voice translation-rule 4
rule 1 /\(.*\)/ /9\1/
voice translation-profile pstn-in
translate calling 2
translate called 1
voice translation-profile pstn-out
translate calling 3
ivr record memory system 15000
ivr record memory session 1000
application
service ajit2013 flash:acme4.vxml
username ajit@spinsci.in
username ajit_tarkar privilege 15 password 7 105D19482B4F110249
username spinsci privilege 15 secret 5 $1$0k5D$bvR0fctDVyqhEgl2jHWKM.
archive
log config
hidekeys
ip tcp path-mtu-discovery
interface Tunnel0
no ip address
shutdown
interface FastEthernet0/0
ip address 183.82.1.68 255.255.224.0
ip nat outside
ip virtual-reassembly
shutdown
duplex auto
speed auto
ip address 192.168.1.220 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1.1
interface FastEthernet1/0
interface FastEthernet1/1
switchport access vlan 10
interface FastEthernet1/2
interface FastEthernet1/3
switchport voice vlan dot1p
interface FastEthernet1/4
interf
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Vlan1
no ip address
shutdown
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
ip http authentication local
no ip http secure-server
tftp-server flash:P00307020200.bin
tftp-server flash:P00307020200.loads
tftp-server flash:P00307020200.sb2
tftp-server flash:P00307020200.sbn
tftp-server flash:P00403020214.bin
control-plane
voice-port 0/0/0
ring cadence pattern01
signal groundStart
cptone IN
timeouts call-disconnect 3
description pstn interface
voice-port 0/0/1
ring cadence pattern06
signal groundStart
cptone IN
description accounts
voice-port 0/2/0
translation-profile outgoing pstn-out
no echo-cancel enable
cptone IN
connection plar opx 4600
description pstn line
voice-port 0/2/1
translation-profile incoming pstn-in
connection plar opx 4500
description vonage line
caller-id enable
ccm-manager music-on-hold
dial-peer voice 1 voip
destination-pattern 7...
voice-class codec 1
session target ipv4:10.2.0.60
incoming called-number .
dtmf-relay h245-alphanumeric rtp-nte
dial-peer voice 2 voip
destination-pattern 4...
voice-class codec 1
session target ipv4:192.168.1.100
dial-peer voice 3 pots
destination-pattern 9T
incoming called-number 5...
port 0/2/1
dial-peer voice 5 pots
destination-pattern 2001
port 0/0/0
dial-peer voice 6 pots
destination-pattern 8T
port 0/2/0
sip-ua
retry invite 5
retry response 10
sip-server ipv4:192.168.1.100
gatekeeper
shutdown
telephony-service
load 7910 P00403020214
load 7960-7940 P00307020200
max-ephones 20
max-dn 20
ip source-address 192.168.1.220 port 2000
auto assign 1 to 20
timeouts interdigit 4
max-conferences 8 gain -6
moh flash:music-on-hold.au
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn-template 3
call-forward busy 2026
call-forward noan 2026 timeout 10
ephone 2
device-security-mode none
description operator
banner motd ^C ^C
alias exec s sh run | sec
line con 0
password 7 15011B5D2A72282D6D
logging synchronous
login
line aux 0
line vty 0 4
password 7 08325C1F2741061E57
login
scheduler allocate 20000 1000
webvpn cef
end
ace FastEthernet1/5
my call manager -192.168.1.100
i have one pstn line to fxo 0/2/0
there is no ITSP , No t1/e1
Hello Ajit
Please post this query under the "Discussions" section to get the advice from the experts.
Laanya
Ajit,
Can you explain the call-flow:
IP-PHONE>>>CUCM>>SIP/H.323/MGCP/SCCP>>>GW>>FXO>>PSTN
From the "show run" it looks like you have a sip-trunk.
If so, can you check the "dial-peer voice 2 voip", its missing the command "session protcol sipv2".
Give it a shot, run the debugs again.
Config t
Logging buffer 50000000 debugging
No logging console
No logging monitor
Logging on
Exit
debug voip vtsp all
debug vpm signa
debug voip ccapi inout
debug ccsip messages
Rate the post accordingly.
-Regards,
Kevin Monteiro
