disable "Actionable Incoming Call Alert" in updatePhone AXL
Lior Mizrahi
I am trying to set "Actionable Incoming Call Alert" to "disabled" in AXL updatePhone.
I see that if I do it through CUCM I get the value as actionableAlert=0.
I tried to send the same parameter on "updatePhone" but it does not change the value.
Is there a way to set it using the AXL API?
npetrele
The value is phone specific, so it appears in the <vendorConfig> section of updatePhone. For example:
<vendorConfig>
     <actionableAlert>0</actionableAlert>
</vendorConfig>
npetrele
<vendorConfig>
</vendorConfig>
