ArrayIndexOutOfBoundsException using subflow with DB Read step
Rosario velardi
I have an issue using subflow. The called script get data from a database. The script works ok if running alone, but if launched with subflow step returns an error ArrayIndexOutOfBoundsException.
In order to isolate the problem i reduced the called script to:
- only 2 steps: DB Read and DB Release
- no params
but the problem remains.
(I am using UCCX 7.0)
Any tip to suggest ?  Regards - Rosario
Aaron Harrison
Probably best to post up your script, or at least deatiled screen grabs of the relevant parts - e.g. the subflow customiser, showing variables, the variables you are writing to, etc etc.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Here the script files and a screen snapshot
Thanks - Rosario
Rosario velardi
Solved. The main script was in local PC and the sub script in the repository.
Thanks a lot - Rosario
