CCE Monitoring and Management
Scott Hanson
Level 3
Level 3
Hello All,
I am looking for a software tool that will do any or all of the following
1) Generate a report on the configuration of Packaged CCE
2) Flag any issues with the configuration
Any thoughts?
All replies rated.  Thanks in advance!
Gergely Szabo
Hi.
I am not aware of any artificial intelligence capable of doing it.
Can you tell me what may be an "issue" with the configuration? I mean it either works as expected and then it's fine or it does not.
G.
Well I am just getting into CCE but judging from these posts it doesn't always work as expected.  I have seen tools that give out a configuration type report on Call Manager and was just hoping something might exists for CCE
Er... This way: if there's a typo in the configuration or some elements are not filled in, the system would let you know. If there's a logical error, however, like an unexpected port or IP address, the system would accept it (and no, it won't double ask you whether you are absolutely sure that this is the right server you are trying to refer to). ICM is not a toy framework. I have been learning it for the last ten years and still I can find something new in it.
G.
