How to put double quote character in a String variable
W S H FERNANDO
Level 4
Level 4
Hi Experts
While Im doing some scripting for REST API Call, my web server needs exact below message ( including the double quotes) in the Body message, But when I make the REST call UCCX is automatically removing the double quotes characters from the variable.
anyone knows how I can put the double quote character inside the String variable?
I tried \" and it didn't work.
Regds
Sasith
Nikhil Aind
Hi Sasith,
Using a backslash will not work due to the defect : CSCuq01978. Try using the '/' instead.
UCCX: Backslashes in String Value As Application Parameter Removed
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuq01978/?reffering_site=dumpcr
Nikhil
***Please rate helpful posts***
unfortunately, I was not working either.
If I want to display (") I put ("/"") which gave me an error.
Are you trying to do this from the appadmin webpage ?  What was the error seen.
Can you try to configure this on the script itself, because passing the variable as a parameter from the script might exhibit different behavior.
Nikhil
Nathan Gageby
Level 4
Level 4
Has there even been a solution for this issue?
