Prioritize incoming calls
dbamkincisco
I am using one CSQ for a number of incoming call numbers. Does anyone know of a way to prioritize calls so that if they come in from a different number it can take prioirity over existing calls in the Queue?
Thank you for any help.
mmelbourne
Level 5
Level 5
You can use the Set Priority step (in IPCCX Enhanced and Premium) to change the default priority of a call; all calls have a default priority of "1". You can set priorities based on called and calling numbers, depending on what you need to achieve.
mmelbourne
Level 5
Level 5
I have IPIVR 3.1(2), how do I find out if it's enhanced or premium version?
Thank you in advance for the help.
The email and http subsystems are only available in the premium version.
Thanks.
