Reason Code Location in SQL Schema
steven.seeger
Community Member
We want to use the Reason Code creation tool to create codes that will be prompted for (back-door Wrap-Up) But, first i need to find the table they are stored in. Does anyone know where these are located in the IPCCx 4.0x data schema?
irisrios
Level 11
Level 11
They will be in the Agent_State_Trace table
i apologize, my posting did not make it clear that we are working with IPCC Express Premium, 4.0.2
i found the table you mention, in ICM's schema
do you have a clue for me regarding ReasonCode in IPCC X's schema? thanks
