Simple Prompt using an if
David Rickard
I'm modifying one of our scripts, and I want to have a main menu prompt play which also plays a message saying 'to hear these options again press star' - but to only play that last little bit once.
However, I can't get the expression editor to play nice!
I have a boolean variable set up in the script called PlayedListenAgain. I also have the prompts set as Prompts.
I added this script to the prompt expression for the menu:
if (PlayedListenAgain == true)
  Prompt promptMainMenu;
else
  Prompt promptMainMenu + promptHearOptionsAgain;
  PlayedListenAgain = true;
But it just errors saying "Unable to parse expression; promptMainMenu is already defined (line: 3, col:3).
Now, I'm well aware of this, I defined it! I'm not trying to redefine it, so I'm going a little nutty here.
Any help gratefully received!
Jonathan Schulenberg
Try this:
  return promptMainMenu;
else
  return promptMainMenu + promptHearOptionsAgain;
Try this:
else
Johnathan, you are a star!
Thankyou, sir. That worked!
