SIP REFER with UCCE and CUPS SIP Proxy
TONY COOPER
Level 4
Level 4
I am running UCCE 8.0.1 with CVP and CUPS as the SIP proxy.  I am looking to transfer calls to PSTN and release from CVP to free CVP ports.  I am using the rfxxxxxxx method in the ICM script, which seems to work fine from CVP.  However the SIP proxy send an Invite to our SBC instead of a REFER.  Is there a way to configure SIP Proxy to send the REFER instead of the invite?  I would like to release the call from our SBC as well.
The other idea was to insert a custom header in CVP I could then pull out at the SBC and replace with a REFER.  Does anyone have any links to documentation on this?
TC
frzhang
how about check "enable send calls to originator" for the refer label routing in CVP? this would bypass proxy.
has someone solved this problem?
