TTS Volume for IPCC Enterprise
ciscoeveris
I would like to configure the TTS volume for the IVR. thre is a TTS.properties file in C:\Program Files\wfavvid\properties but the only parameter that appears in this file is to make TTS slower,I think thre should be a paramter to add in this file in order to modify the volume of TTS. Thank you.
gmarogi
Level 5
Level 5
You can use some free tool such as "wavepad" to increasethe gain without any issue.
