UCCX 10.5 - Call Progress Analysis (CPA) with FXO - instantly going to IVR Script (debug attached)
BRIAN WYLAND
Due to Telco required Account codes on our PRI we have dedicated analog lines for outbound dialing on our 2921 router.
We have configured CPA and CUBE on the gateway but for some reason as soon as the call is picked up it goes instantly to the IVR Script.
I have read that the FXO's units are supported with CPA,  but when asking TAC for support/debugging help I was told by my first engineer that FXO's are not supported.
Here are the important parts of the Router configuration:
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.155-3.M2.bin
boot-end-marker
voice-card 0
voice-service dsp-reservation 75
dspfarm
dsp services dspfarm
voice service voip
no ip address trusted authenticate
cpa timing live-person 2501
cpa timing term-tone 15500
cpa threshold active-signal 9db              <----- We have tried lower and higher numbers and no change
mode border-element
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Voice Network
ip address 172.16.24.2 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.16.24.2
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
sccp ccm group 1
associate ccm 10 priority 1
associate ccm 11 priority 2
associate profile 1 register CFB12345
associate profile 2 register MTP12345
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 15
dspfarm profile 2 transcode
description TRANSCODE
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
call-progress-analysis
maximum sessions 25
associate application CUBE
dial-peer voice 7401 voip
preference 2
destination-pattern ^[0-8]...$
session target ipv4:172.18.200.131
incoming called-number ^....$
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
no vad
dial-peer voice 7400 voip
preference 1
session target ipv4:172.18.200.132
voice-class codec 1
voice-class h323 1
no vad
And below are the debugs from some calls outbound - mostly just pickup and saying "Hello" - but before we can even speak the IVR script starts
Mar 17 2016 12:40:13 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:940XXXXXXXX@172.16.24.2:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.18.200.135:5065;branch=z9hG4bKS4d2CTwBBbvx6.afxpo+QA~~57
Max-Forwards: 70
To: <sip:940XXXXXXXX@172.16.24.2>
From: <sip:40XXXXXXXX@172.18.200.135>;tag=ds2ab26e05
Call-ID: 145823281337519@172.18.200.135
CSeq: 100 INVITE
Content-Length: 528
Contact: <sip:40XXXXXXXX@172.18.200.135:5065;transport=udp>
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, NOTIFY
Cisco-Guid: 652422263-906326781-1521488512-80648069
User-Agent: Cisco-UCCX/8.5
Expires: 120
MIME-Version: 1.0
Content-Type: multipart/mixed;boundary=unique_boundary
--unique_boundary
Content-Type: application/sdp
Content-Disposition: session;handling=required
v=0
o=Cisco-UCCX 1855 1 IN IP4 172.18.200.135
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
m=audio 12345 RTP/AVP 0
a=rtpmap:0 PCMU/8000
a=ptime:20
--unique_boundary
Content-Type: application/x-cisco-cpa
Content-Disposition: signal;handling=optional
Events=FT,Asm,AsmT,Sit
CPAMinSilencePeriod=375
CPAAnalysisPeriod=2500
CPAMaxTimeAnalysis=3000
CPAMinValidSpeechTime=112
CPAMaxTermToneAnalysis=15000
--unique_boundary--
Mar 17 2016 12:40:13 EDT: //-1/26E32C775AB0/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=40XXXXXXXX
----- ccCallInfo IE subfields -----
cisco-ani=40XXXXXXXX
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=940XXXXXXXX
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Mar 17 2016 12:40:13 EDT: //-1/26E32C775AB0/CCAPI/cc_api_call_setup_ind_common:
Interface=0x3F5BDBEC, Call Info(
Calling Number=40XXXXXXXX,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=940XXXXXXXX(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=777, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=81
Mar 17 2016 12:40:13 EDT: //-1/26E32C775AB0/CCAPI/ccCheckClipClir:
In: Calling Number=40XXXXXXXX(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=40XXXXXXXX(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar 17 2016 12:40:13 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 17 2016 12:40:13 EDT: :cc_get_feature_vsa malloc success
Mar 17 2016 12:40:13 EDT: cc_get_feature_vsa count is 1
Mar 17 2016 12:40:13 EDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1049583584,feature_id:125
Mar 17 2016 12:40:13 EDT: //81/26E32C775AB0/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=40XXXXXXXX(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=940XXXXXXXX(TON=Unknown, NPI=Unknown))
Mar 17 2016 12:40:13 EDT: //81/26E32C775AB0/CCAPI/cc_process_call_setup_ind:
Event=0x22A12210
Mar 17 2016 12:40:13 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 940XXXXXXXX
Mar 17 2016 12:40:13 EDT: //81/26E32C775AB0/CCAPI/ccCallSetContext:
Context=0x3DE4D6F0
>>>>CCAPI handed cid 81 with tag 777 to app "_ManagedAppProcess_Default"
Mar 17 2016 12:40:13 EDT: //81/26E32C775AB0/CCAPI/ccCallProceeding:
Mar 17 2016 12:40:13 EDT: //81/26E32C775AB0/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=545, Params=0x3DE4ECF0, Progress Indication=NULL(0)
Mar 17 2016 12:40:13 EDT: //81/26E32C775AB0/CCAPI/ccCheckClipClir:
Destination Pattern=9T, Called Number=940XXXXXXXX, Digit Strip=TRUE
Redirect Number=, Display Info=
Account Number=40XXXXXXXX, Final Destination Flag=TRUE,
Guid=26E32C77-3605-72FD-5AB0-128004CE9785, Outgoing Dial-peer=545
Mar 17 2016 12:40:13 EDT: //81/26E32C775AB0/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=940XXXXXXXX
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Mar 17 2016 12:40:13 EDT: //81/26E32C775AB0/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x3FD7BB20, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=40XXXXXXXX,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=940XXXXXXXX(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=545, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Mar 17 2016 12:40:13 EDT: cc_get_feature_vsa count is 2
Mar 17 2016 12:40:13 EDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1049582912,feature_id:126
Mar 17 2016 12:40:13 EDT: //-1/xxxxxxxxxxxx/VTSP:(0/1/0):-1:-1:-1/vtsp_allocate_cdb:
CDB=0x2100FD30
Mar 17 2016 12:40:13 EDT: //-1/xxxxxxxxxxxx/VTSP:(0/1/0):-1:-1:-1/vtsp_insert_cdb:
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/CCAPI/ccCallSetContext:
Context=0x3DE4ECA0
Mar 17 2016 12:40:13 EDT: //81/26E32C775AB0/CCAPI/ccSaveDialpeerTag:
Mar 17 2016 12:40:13 EDT: //-1/xxxxxxxxxxxx/VTSP:(0/1/0):-1:-1:-1/vtsp_process_event:
[state:INVALID STATE MACHINE, event:E_CC_SETUP_REQ]
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:-1:-1/vtsp_og_call_req:
Echo Cancel=TRUE, Gain Control=0
Auto Gain Control=FALSE, Dual Tone Detect Mask=0x0, Seq Tone Detect=FALSE
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:-1:-1/vtsp_do_call_setup_req:
Mar 17 2016 12:40:13 EDT: //-1/xxxxxxxxxxxx/HPI/[]/hpi_dspmgr_open:
Mar 17 2016 12:40:13 EDT: hpi [] DSP [0/0x0] S_HPI_CLOSED(0) E_HPI_DSPRM_OPEN/SET_CODEC(61)
Mar 17 2016 12:40:13 EDT: HPI/[]/hpi_dspmgr_open:
tdm_info=0x0, tsp_info=0x0, dsp_sdb=0x229FFE44
call_id=82, dsprm_type=32
Mar 17 2016 12:40:13 EDT: hpi [] DSP [0/0x0] -> S_HPI_CLOSED(0)
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_dspmgr_open:
Allocated DSP resource: 0/1:1; dsp_intf=0x21B22424 hpi_cdb=0x3E9199D0 ret=1
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_dspmgr_open: exit@26736
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_opened_cb:
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_process_event:
[state:S_SETUP_REQ_PEND, event:E_VTSP_DSM_OPEN_SUCCESS]
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/act_setup_req_pend_succ:
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_request_call:
Mode=0, Peer=545
Mar 17 2016 12:40:13 EDT: digit_strip:1, pcn:940XXXXXXXX, poa:9T
Mar 17 2016 12:40:13 EDT: pcn:40XXXXXXXX, poa:T
Mar 17 2016 12:40:13 EDT: Final pcn:40XXXXXXXX, poa:T, dial_string:40XXXXXXXX
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_create_call_active_on_setup_req:
Target Carrier ID=
Source Carrier ID=
Progress Indication=0, Info Trans Capability=0
Calling Number=40XXXXXXXX, TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed
Called Number=940XXXXXXXX, TON=Unknown, NPI=Unknown
[state:S_SETUP_REQUEST, event:E_TSP_PROCEEDING]
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/act_setup_pend_proceeding:
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_timer:
Timer Start Time=763474, Timer Value=25000(ms)
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/CCAPI/cc_api_call_proceeding:
Interface=0x3FD7BB20, Progress Indication=NULL(0)
Peer=545, Progress Indication=0, Return Code=2
[state:S_NULL, event:E_VTSP_DSM_OPEN_SUCCESS]
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/act_setup_req_wait_pend_success:
Event=76
Mar 17 2016 12:40:13 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_timer_stop:
Timer Stop Time=763474
Mar 17 2016 12:40:13 EDT: //81/26E32C775AB0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 17 Mar 2016 16:40:13 GMT
CSeq: 100 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.5.3.M2
Content-Length: 0
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_process_event:
[state:S_SETUP_REQ_PROC, event:E_TSP_DIAL]
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/act_setup_pend_dial:
Digits=40XXXXXXXX, Tone Mode=0
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dial:
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/ds_do_dial:
Digits To Dial=40XXXXXXXX
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_init:
Open channel
Packet details:
Packet Length=20, Channel Id=1, Packet Id=74
ALawULawSelect=A Law, Associated SignalingChannel=128
Timeslot=0, SerialPort=0
ha_control_flag=0, ha_chk_point_interval=0
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_send_message:
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_CLOSED(0) E_HPI_DSP_OPEN_VOICE_CHANNEL(11)
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/caplog_hpi_msg_log:
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] -> S_HPI_IDLE(1)
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_open_service:
Setting codec g711ulaw
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_set_codec:
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_IDLE(1) E_HPI_DSPRM_OPEN/SET_CODEC(61)
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_dsprm_callback:
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_voice_config_params:
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_encap_config:
RTP information
Packet details:
Packet Length=44, Channel Id=1, Packet Id=92 TransportProtocol=2
Tx SSRC=0x00, Rx SSRC=0x00, Tx VPXCC=0x0, Rx VPXCC=0x0
SID support=1, TSE payload=101, Sequence number start=0x0, Redundancy=0
ClearChannel payload type=0, Fax payload type=0, ALaw PCM switchover=0
MuLaw PCM switchover=0, DTMF payload type=0, NTE receive payload type=101, sprt payloadtype=0
Lmr tone payload type=0, NTE tone payload type=0
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_IDLE(1) E_HPI_DSP_ENC_CONFIG(29)
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_set_playout_config:
Packet details:
Packet Length=18, Channel Id=1, Packet Id=76
Mode=1, Initial=60(ms), Min=40(ms), Max=1000(ms), fax_nom=300(ms)
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_IDLE(1) E_HPI_DSP_SET_VOICE_PLAYOUT_DELAY(13)
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_info_field_size_config:
Info field size=160
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_idle_code_det:
Packet details:
Packet Length=14, Channel Id=1, Packet Id=116
Enable=FALSE, Code=0x00000000, Duration=6000(ms)
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_IDLE(1) E_HPI_DSP_IDLE_CODE_CONTROL (51)
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_echo_cancel:
Packet details:
Packet Length=22, Channel Id=1, Packet Id=66
Flags=0x00000F00, NLP Threshold=-21(dB), Suppressor Coverage=7(s), Attenuation=2(s), fx_mode=0
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_IDLE(1) E_HPI_DSP_ECHO_CANCELLER_CONTROL(3)
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_cng_config:
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_start_service:
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_voice_mode:
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_enable_mediaforking:
Mar 17 2016 12:40:14 EDT: invalid event -1 of type 0
Packet details:
Packet Length=34, Channel Id=1, Packet Id=73
CodingType=1, Voice field size=160(bytes), VAD Flag=0,
Echo Length=128(ms), ComfortNoise=enable, Inband detect=0x00000001,
DigitRelay=0, AGC Flag=0, ECAN TestGroup=0,
ECAN TestNumber=0, DynamicPayload=0, ANS Tone Treatment=0
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_IDLE(1) E_HPI_DSP_VOICE_MODE(10)
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] -> S_HPI_VOICE(2)
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_start_service: exit@4915
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_call_progress_detect:
Mar 17 2016 12:40:14 EDT: //-1/xxxxxxxxxxxx/HPI/[]/hpi_call_progress_detect:
cpaInfo->cpaFlag=0x2
tone_type=24, enable=1, control=9,
minSilencePeriod=375, machineGreetingTime=2500,
detectionTimeout=65535, noiseThresholdPeriod=100,
minValidSpeechTime=112, maxNoiseFloor=10000, minNoiseFloor=1000, activeThreshold=64,
silenceDebouncePeriod=112, maxTermToneAnalysis=15000,
minTermToneFreq=300, minTermToneDuration=80
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_VOICE(2) E_HPI_DSP_INBAND_DETECTOR_CONTROL(45)
Packet details:
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_VOICE(2) E_HPI_DSP_ECHO_CANCELLER_CONTROL(3)
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_set_gain:
Packet details:
Packet Length=12, Channel Id=1, Packet Id=91
Gain: In=0.0(dB), Out=6550.6(dB)
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_VOICE(2) E_HPI_DSP_SET_GAINS(28)
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_agc_control:
Packet details:
Packet Length=14, Channel Id=1, Packet Id=98
AGC control: In= off, 0(dBm), Out=off, 0(dBm)
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_digit_relay_config:
Packet details:
Packet Length=10, Channel Id=1, Packet Id=85
Mode=2
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_VOICE(2) E_HPI_DSP_DIGIT_RELAY(22)
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_vad_enable:
Packet details:
Packet Length=8, Channel Id=1, Packet Id=77
VAD=0 (OFF)
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_VOICE(2) E_HPI_DSP_VAD_DISABLE(14)
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_dtmf_mode:
Packet details:
Packet Length=10, Channel Id=1, Packet Id=65
dtmf_or_mf=0
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_VOICE(2) E_HPI_DSP_DTMF_MODE(2)
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] -> S_HPI_DTMF(3)
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_voice_gen_dial_digit:
Packet details:
Packet Length=132, Channel Id=1, Packet Id=90
DigitCount=10, Time: ON=100(ms), OFF=100(ms)
Mar 17 2016 12:40:14 EDT: [4] components=2, 770/1209(hz), 16462/20724(dBm0)
Mar 17 2016 12:40:14 EDT: [0] components=2, 941/1336(hz), 16462/20724(dBm0)
Mar 17 2016 12:40:14 EDT: [7] components=2, 852/1209(hz), 16462/20724(dBm0)
Mar 17 2016 12:40:14 EDT: [6] components=2, 770/1477(hz), 16462/20724(dBm0)
Mar 17 2016 12:40:14 EDT: [2] components=2, 697/1336(hz), 16462/20724(dBm0)
Mar 17 2016 12:40:14 EDT: [5] components=2, 770/1336(hz), 16462/20724(dBm0)
Mar 17 2016 12:40:14 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_DTMF(3) E_HPI_DSP_DIAL_DIGIT(27)
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_receive_message:
Packet details:
Packet Id=192
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_receive_message: DTMF digit notification
Packet details:
Packet Length=14, Channel Id=1, Packet Id=192
Digit=0(0), RTP Timestamp=00EBEB07C3
Mar 17 2016 12:40:14 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_digit_begin_cb:
Begin Digit=0
Digit Reporting=FALSE, Digit Consume=FALSE, Digit Relay=FALSE
Mar 17 2016 12:40:15 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_receive_message:
Mar 17 2016 12:40:15 EDT: //82/26E32C775AB0/HPI/[0/1:1]/caplog_hpi_msg_log:
Packet details:
Packet Id=203
DTMF digit end notification
Packet details:
Packet Length=12, Channel Id=1, Packet Id=203
Digit=0(0), Duration=127(ms)
Mar 17 2016 12:40:15 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_digit_end_cb:
Mar 17 2016 12:40:15 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_timer_stop:
Timer Stop Time=763639
End Digit=0
Packet details:
Packet Id=192
Mar 17 2016 12:40:15 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_receive_message: DTMF digit notification
Packet details:
Digit=7(7), RTP Timestamp=00EBEB0E03
Mar 17 2016 12:40:15 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_digit_begin_cb:
Begin Digit=7
Packet details:
Packet Id=203
Packet details:
Digit=7(7), Duration=127(ms)
Timer Stop Time=763659
End Digit=7
Packet details:
Packet Id=192
Packet details:
Digit=4(4), RTP Timestamp=00EBEB1443
Begin Digit=4
Packet details:
Packet Id=203
Packet details:
Digit=4(4), Duration=127(ms)
Timer Stop Time=763679
End Digit=4
Packet details:
Packet Id=192
Packet details:
Digit=6(6), RTP Timestamp=00EBEB1A83
Begin Digit=6
Packet details:
Packet Id=203
Packet details:
Digit=6(6), Duration=127(ms)
Timer Stop Time=763699
End Digit=6
Packet details:
Packet Id=192
Packet details:
Digit=2(2), RTP Timestamp=00EBEB20C3
Begin Digit=2
Packet details:
Packet Id=203
Packet details:
Digit=2(2), Duration=127(ms)
Timer Stop Time=763719
End Digit=2
Packet details:
Packet Id=192
Packet details:
Digit=4(4), RTP Timestamp=00EBEB2703
Begin Digit=4
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_receive_message:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/caplog_hpi_msg_log:
Packet details:
Packet Id=203
Packet details:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_digit_end_cb:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_timer_stop:
Timer Stop Time=763739
End Digit=4
Packet details:
Packet Id=192
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_receive_message: DTMF digit notification
Packet details:
Digit=4(4), RTP Timestamp=00EBEB2D43
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_digit_begin_cb:
Begin Digit=4
Packet details:
Packet Id=203
Packet details:
Timer Stop Time=763759
End Digit=4
Packet details:
Packet Id=192
Packet details:
Digit=4(4), RTP Timestamp=00EBEB3383
Begin Digit=4
Packet details:
Packet Id=203
Packet details:
Timer Stop Time=763779
End Digit=4
Packet details:
Packet Id=192
Packet details:
Digit=5(5), RTP Timestamp=00EBEB39C3
Begin Digit=5
Packet details:
Packet Id=203
Packet details:
Digit=5(5), Duration=127(ms)
Timer Stop Time=763799
End Digit=5
Packet details:
Packet Id=195
Dialing done notification
Packet details:
Packet Length=8, Channel Id=1, Packet Id=195
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_dial_done_cb:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_process_event:
[state:S_DS_DIALING, event:E_VTSP_DSM_DIALING_COMPLETE]
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/ds_dialing:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/ds_do_dial:
Digits To Dial=
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_digit_pop:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/act_setup_pend_dial_comp:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/ds_do_dial:exit@572
[state:S_SETUP_REQ_PROC, event:E_TSP_PROGRESS]
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/act_setup_pend_progress:
Progress Indication=8, Signal Indication=2, cdb->answer_supervision=0
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/CCAPI/cc_api_call_cut_progress:
Interface=0x3FD7BB20, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Cause Value=0
Call Entry(Responsed=TRUE)
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_ring_noan_timer_start:
Timer Start Time=763806, No Answer Timer Value=180000(ms)
Mar 17 2016 12:40:16 EDT: //81/26E32C775AB0/CCAPI/ccCallCutProgress:
Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Mar 17 2016 12:40:16 EDT: //81/26E32C775AB0/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID1=0x51, gcid=C1814DE2-EB9511E5-806EA089-9F7E9089, tag=0x0)
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID2=0x52, gcid=C1814DE2-EB9511E5-806EA089-9F7E9089, tag=0x0)
Conference Id=0xFFFFFFFF, Call Id1=81, Call Id2=82, Tag=0x0
Mar 17 2016 12:40:16 EDT: //81/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Mar 17 2016 12:40:16 EDT: cc_api_get_xcode_stream : 4983
Mar 17 2016 12:40:16 EDT: //81/26E32C775AB0/CCAPI/cc_api_bridge_done:
Conference Id=0x21, Source Interface=0x3F5BDBEC, Source Call Id=81,
Destination Call Id=82, Disposition=0x0, Tag=0x0
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_bridge_check_cb:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_bridge_check_cb:exit@1496
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_bridge_status_cb:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/CCAPI/cc_api_bridge_done:
Conference Id=0x21, Source Interface=0x3FD7BB20, Source Call Id=82,
Destination Call Id=81, Disposition=0x0, Tag=0xFFFFFFFF
Mar 17 2016 12:40:16 EDT: //81/26E32C775AB0/CCAPI/cc_generic_bridge_done:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_save_fax_config:
Fax Relay=ENABLED
Primary Fax Protocol=T38_FAX_RELAY, Fallback Fax Protocol=NONE_FAX_RELAY
Fax Relay CM Suppression :=ENABLED, Fax Relay ANS Suppression :=DISABLED
Fax Parameters Set By=Dialpeer, Peer=777
Fax Version:=0, LS Red=0, HS Red=0
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_set_fax_feat_param:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_save_tty_config:
Save TTY configuration
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_set_tty_feat_param:
Set TTY feat parameters
Call Entry(Conference Id=0x21, Destination Call Id=82)
Call Entry(Conference Id=0x21, Destination Call Id=81)
Mar 17 2016 12:40:16 EDT: confID:0x21; callEntry1 callID1:0x51, type:3; callEntry2 callID2:0x52, type:6
[state:S_SETUP_REQ_PROC, event:E_CC_DO_CAPS_IND]
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_peer_event_cb:
Event=E_DSM_CC_CAPS_IND
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/CCAPI/cc_api_caps_ind:
Destination Interface=0x3F5BDBEC, Destination Call Id=81, Source Call Id=82,
Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
Mar 17 2016 12:40:16 EDT: //81/26E32C775AB0/CCAPI/cc_api_caps_ind:
Destination Interface=0x3FD7BB20, Destination Call Id=82, Source Call Id=81,
Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x2,
Modem=0x0, Codec Bytes=160, Signal Type=2)
Mar 17 2016 12:40:16 EDT: //81/26E32C775AB0/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=ON(0x2),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
[state:S_SETUP_REQ_PROC, event:E_CC_CAPS_IND]
Event=E_DSM_CC_CAPS_ACK
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/CCAPI/cc_api_caps_ack:
Mar 17 2016 12:40:16 EDT: //81/26E32C775AB0/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=81
Mar 17 2016 12:40:16 EDT: //81/26E32C775AB0/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x21, Call Id1=81, Call Id2=82
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_stop_service:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_idle_service:
Packet details:
Packet Length=8, Channel Id=1, Packet Id=68
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_send_message:
Mar 17 2016 12:40:16 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_DTMF(3) E_HPI_DSP_IDLE_MODE(5)
Mar 17 2016 12:40:16 EDT: hpi [0/1/0 (82)] DSP [1/0x1] -> S_HPI_IDLE(1)
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_open_service:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_set_codec:
Mar 17 2016 12:40:16 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_IDLE(1) E_HPI_DSPRM_OPEN/SET_CODEC(61)
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_dsprm_callback:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_voice_config_params:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_encap_config:
RTP information
Packet details:
Tx SSRC=0x01EDC, Rx SSRC=0x00, Tx VPXCC=0x80, Rx VPXCC=0x0
SID support=0, TSE payload=101, Sequence number start=0x1, Redundancy=0
ClearChannel payload type=125, Fax payload type=122, ALaw PCM switchover=8
MuLaw PCM switchover=0, DTMF payload type=121, NTE receive payload type=101, sprt payloadtype=0
Mar 17 2016 12:40:16 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_IDLE(1) E_HPI_DSP_ENC_CONFIG(29)
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_set_playout_config:
Packet details:
Mar 17 2016 12:40:16 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_IDLE(1) E_HPI_DSP_SET_VOICE_PLAYOUT_DELAY(13)
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_info_field_size_config:
Info field size=160
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_modem_relay_protocol_config:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_idle_code_det:
Packet details:
Mar 17 2016 12:40:16 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_IDLE(1) E_HPI_DSP_IDLE_CODE_CONTROL (51)
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_echo_cancel:
Packet details:
Mar 17 2016 12:40:16 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_IDLE(1) E_HPI_DSP_ECHO_CANCELLER_CONTROL(3)
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_cng_config:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_start_service:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_voice_mode:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_enable_mediaforking:
Mar 17 2016 12:40:16 EDT: invalid event -1 of type 0
Packet details:
DigitRelay=2, AGC Flag=0, ECAN TestGroup=0,
Mar 17 2016 12:40:16 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_IDLE(1) E_HPI_DSP_VOICE_MODE(10)
Mar 17 2016 12:40:16 EDT: hpi [0/1/0 (82)] DSP [1/0x1] -> S_HPI_VOICE(2)
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_start_service: exit@4915
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_call_progress_detect:
Mar 17 2016 12:40:16 EDT: //-1/xxxxxxxxxxxx/HPI/[]/hpi_call_progress_detect:
Mar 17 2016 12:40:16 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_VOICE(2) E_HPI_DSP_INBAND_DETECTOR_CONTROL(45)
Packet details:
Mar 17 2016 12:40:16 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_VOICE(2) E_HPI_DSP_ECHO_CANCELLER_CONTROL(3)
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_set_gain:
Packet details:
Mar 17 2016 12:40:16 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_VOICE(2) E_HPI_DSP_SET_GAINS(28)
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_agc_control:
Packet details:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_digit_relay_config:
Packet details:
Mode=2
Mar 17 2016 12:40:16 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_VOICE(2) E_HPI_DSP_DIGIT_RELAY(22)
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_vad_enable:
Packet details:
Packet Length=18, Channel Id=1, Packet Id=78
VAD=1 (ON): Threshold=-38(dBm), VADTime=250(ms), Aggressive=0, Noise Threshold=-62(dBm), RPT=0
Mar 17 2016 12:40:16 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_VOICE(2) E_HPI_DSP_VAD_ENABLE(15)
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_feature_notify_cb:
Feature ID=0, Feature Status=1
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_reactivate_ringback:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_reactivate_ringback:exit@1287
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/CCAPI/cc_api_voice_mode_event:
Call Id=82
Call Entry(Context=0x3DE4ECA0)
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_inband_det_ctrl:
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_inband_det_ctrl: exit@13098
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_fax_enable:
Packet details:
Packet Length=16, Channel Id=1, Packet Id=111
SignalType=2, Mode=2, Signal suppression bitmap 3
[state:S_SETUP_REQ_PROC, event:E_TSP_CONNECT]
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/act_setup_pend_connect:
Progress Indication=2
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_ring_noan_timer_stop:
Timer Stop Time=763808
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/CCAPI/cc_api_call_connected:
Interface=0x3FD7BB20, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
cpaInfo->cpaFlag=0x3
tone_type=24, enable=1, control=23,
detectionTimeout=3000, noiseThresholdPeriod=100,
Mar 17 2016 12:40:16 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_inband_tone_off:
CPTone OFF
Packet details:
Packet Length=8, Channel Id=1, Packet Id=71
Mar 17 2016 12:40:16 EDT: hpi [0/1/0 (82)] DSP [1/0x1] S_HPI_VOICE(2) E_HPI_DSP_CP_TONE_OFF(8)
Mar 17 2016 12:40:16 EDT: //81/26E32C775AB0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: <sip:940XXXXXXXX@172.16.24.2>;tag=748C38-51F
CSeq: 100 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Remote-Party-ID: <sip:40XXXXXXXX@172.16.24.2>;party=called;screen=no;privacy=off
Contact: <sip:940XXXXXXXX@172.16.24.2:5060>
Supported: sdp-anat
Content-Type: multipart/mixed;boundary=uniqueBoundary
Mime-Version: 1.0
Content-Length: 430
--uniqueBoundary
v=0
o=CiscoSystemsSIP-GW-UserAgent 6255 8577 IN IP4 172.16.24.2
s=SIP Call
c=IN IP4 172.16.24.2
t=0 0
m=audio 16448 RTP/AVP 0
a=ptime:20
--uniqueBoundary
event=enabled
--uniqueBoundary--
Mar 17 2016 12:40:16 EDT: //81/26E32C775AB0/CCAPI/ccCallConnect:
Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
Call Entry(Connected=TRUE, Responsed=TRUE)
Sent:
SIP/2.0 200 OK
CSeq: 100 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Mime-Version: 1.0
Content-Length: 430
--uniqueBoundary
v=0
s=SIP Call
t=0 0
a=ptime:20
--uniqueBoundary
event=enabled
--uniqueBoundary--
Mar 17 2016 12:40:16 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:940XXXXXXXX@172.16.24.2:5060 SIP/2.0
Via: SIP/2.0/UDP 172.18.200.135:5065;branch=z9hG4bKS4d2CTwBBbvx6.afxpo+QA~~58
Max-Forwards: 70
CSeq: 100 ACK
Content-Length: 0
Mar 17 2016 12:40:19 EDT: //82/26E32C775AB0/HPI/[0/1:1]/hpi_receive_message:
Mar 17 2016 12:40:19 EDT: //82/26E32C775AB0/HPI/[0/1:1]/caplog_hpi_msg_log:
Packet details:
Packet Id=193
CPA Event (0x5) detected
Packet details:
Packet Length=36, Channel Id=1, Packet Id=193
tone_id=5, pickup_time=0, max_act_glitch=0
num_act_glitches=0, valid_speech_time=0, max_post_sil_glitch=0
num_post_sil_glitch=0, silence_period=0, term_tone_det_time=0
noise_threshold=1000, act_threshold_hi=0, act_threshold_lo=64000
Packet details:
Packet Id=193
CPA Event (0x6) detected
Packet details:
tone_id=6, pickup_time=0, max_act_glitch=0
Packet details:
Packet Id=193
CPA Event (0x7) detected
Packet details:
tone_id=7, pickup_time=0, max_act_glitch=0
Mar 17 2016 12:40:19 EDT: //82/26E32C775AB0/VTSP:(0/1/0):-1:1:1/vtsp_dsm_media_event_cb:
Event=E_DSMP_DSP_CPA_EVENT_TONE
Mar 17 2016 12:40:19 EDT: //81/26E32C775AB0/SIP/Msg/ccsipDisplayMsg:
Sent:
UPDATE sip:40XXXXXXXX@172.18.200.135:5065;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.16.24.2:5060;branch=z9hG4bK602330
To: <sip:40XXXXXXXX@172.18.200.135>;tag=ds2ab26e05
Date: Thu, 17 Mar 2016 16:40:16 GMT
User-Agent: Cisco-SIPGateway/IOS-15.5.3.M2
Max-Forwards: 70
Supported: timer,resource-priority,replaces,sdp-anat
Timestamp: 1458232819
CSeq: 101 UPDATE
Min-SE: 1800
Content-Length: 26
event=detected
status=CpaS
Received:
SIP/2.0 200 Ok
CSeq: 101 UPDATE
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 172.16.24.2:5060;branch=z9hG4bK6118A5
Max-Forwards: 70
ws-ch-vg01#
ws-ch-vg01#
0 Replies 0
