UCCX help with reporting in uccx
sukhigrwl
Hello All,
we running UCCX 10.6 in our environment and just wondering if there's an option in uccx reporting that can genrate a report on based inquiry that how many calls go to hold Queue?
Thanks for all the input
Sukhdeep
6 Replies 6
Hello Chakshu,
thanks for your reply and time.
I look at the report suggested by you but it kind makes me more confused as the total sum of all calls is off by 5 calls.
for example, it showing me total handled calls 708.
 0-15=  655
0-30 = 699 (so difference is 44)
0-45 = 702 (difference is 3)
0-60=703 (the difference is 1)
so total is 655+44+3+1=703
Abandoned Calls list showing same too.
total 15 but when I do the counting number comes around 8
just not sure where all missing calls go? is there any other report which gives me information on those missing calls numbers?
once again thanks for your help
Its not suggested to compare the two reports, the reporting template used for the calculations are different.
However you can raise a TAC to get more clarification, to understand the depth why there is a difference.
Hello Chakshu,
I was not comparing two reports. just some misunderstanding with one reports but a reply from "brianbatty"  clear my misunderstanding and I am good now.
Thanks for you all help
You handled 703 calls within the 0s to 60s timeframe - the 5 'missing' calls took longer than 60s to handle.
oh.....lol
Thanks for the clarification
