UCCX. Script Editor. String conversion.
DOM.RF NOC
Level 2
Level 2
Colleagues, good day!
Please tell me such a simple thing: how in UCCX script editor convert a string like:
"User [type = Call Manager User, id = aa.ivanov, authenticated = true]"
in the following string:
"aa.ivanov"
I'm not familiar with the Java programming language, and I'm having some difficulty with this.
Thanks in advance!
you might want to use the Get User Info step. Then map the identifier field to a String variable.
G.
Gergely Szabo
OK, from the beginning. What is the original variable type (the one with User [type etc)?
G.
Yes, originally it is a user type variable. And i need to get only user id in string variable.
G.
Thank you very much, everything worked out. This option is much easier.
