07-19-2004 05:02 AM - edited 03-13-2019 10:26 PM
Hi all,
I'm trying to create vxml document with menu. But it doesn't work. Only play promt and that's all.
<?xml version="1.0"?>
<vxml version="2.0">
<menu id="testmenu" dtmf="true">
<prompt bargein="true">
<audio src="http://10.1.22.236/audio/welcome.au"></audio>
</prompt>
<choice next="http://10.1.22.236/vxml/acme1.vxml"/>
<choice next="http://10.1.22.236/vxml/audio.vxml"/>
</menu>
</vxml>
Can anyone tell me where the problem should be?
Mirek
07-19-2004 06:20 AM
Please take a look at the below URL, which explains VXML scripting with example. http://www.voicexml.org/specs/VoiceXML-100.pdf
Hope it helps.
Venkat
10-13-2004 01:14 PM
The problem is in the choice tag!
Try this:
Hope this helps!!
