ACI Toolkit's OS and Python requirements
Niels
Frequent Visitor
Frequent Visitor
I am preparing some ACI API testing scenario's and would like to make use of acitoolkit.
Now I would like to know;
- Does acitoolkit run with Python 3 or not?
- Which Linux platform and version is best to use for acitoolkit to run on.
Many thanks for the reply!
CSCO12550173
Level 2
Level 2
Hello, you need whatever linux distro, you can use ubuntu or centos
i thinks it use 2.7, but it doesn't care about the version, because you can use what's come in the machine
and start to build a scripts
TK88117
Community Member
I found this runs very well with centos 8 and python3.7
one problem was the diagram app section
Exercise 3: ACI Toolkit Apps
one dependency is not available in the standard centos repos anymore so YUM fails for:
graphviz-devel.x86_64
to get this to work enable Centos PowerTools repo  (via GUI software tools or CLI - disabled by default)
you can then install from this repository and the lab works nicely
  sudo yum repo-pkgs PowerTools list | grep graphviz
  sudo yum repo-pkgs PowerTools install graphviz-devel.x86_64
