Error while using aci-toolkit
chungewa
HI, Guys
I'm using Python2.7 and ACI SDK, and i can create Tenant into my APIC successfully.
But When i try to create Tenant from ACI-toolkit, i got the error:
Thanks for your sharing
Jason
Python 2.7.6 (default, Nov 10 2013, 19:24:24) [MSC v.1500 64 bit (AMD64)] on win32
Type "copyright", "credits" or "license()" for more information.
>>> from acitoolkit import *
>>> from credentails import *
Traceback (most recent call last):
  File "<pyshell#1>", line 1, in <module>
ImportError: No module named credentails   // so i using the following to login
>>> apicUrl = 'https://my-aci-address'
>>> from cobra.mit.access import MoDirectory
>>> from cobra.mit.session import LoginSession
>>> loginSession = LoginSession(apicUrl,'admin','cisco123')
>>> moDir = MoDirectory(loginSession)
>>> moDir.login()
>>> tenant = Tenant ('chungewa-ten2')
  File "<pyshell#9>", line 1, in <module>
                          NameError: name 'Tenant' is not defined   where am I wrong
Here is some information in the samples/README.md
"Many of the samples in this directory use the file credentials.py to login to the APIC.  Before running, edit the credentials.py with the username, password, and IP address for your environment."
So create a credentials.py file in the same directory as your code and have in it values for URL, LOGIN and PASSWORD as the credentials to access the APIC. Below is an example.
## credentials.py
URL="http://127.0.0.1"
LOGIN="chungewa"
PASSWORD="Cisco123"
- Omar
10 Replies 10
Omar Shorbaji
Community Member
Hi Jason,
It looks to me that you need to do a couple of things:
First,
from acitoolkit.acitoolkit import *
instead of
Second, check the spelling of credentials. You spell it as credentails ("a" and "i" are reversed). I do not know if that is intentional.
- Omar
HI, Omar
after reinstall acitoolkit, i'v referenced this http://datacenter.github.io/acitoolkit/docsbuild/html/tutorial.html#building-a-simple-tenant-configuration
>>> from credentials import *         //copied from in above URL
ImportError: No module named credentials
## credentials.py
LOGIN="chungewa"
PASSWORD="Cisco123"
- Omar
Thanks Omar:
modify credentials.py and put under my python2.7 directory, that works.
jdanrich
I am having the same issue.. But it's not credential related..
$ python aci-doc.py
  File "aci-doc.py", line 4, in <module>
    import cobra.mit.access
ImportError: No module named cobra.mit.access
I've searched and I don't appear to have this module anywhere..  Does anyone know a location to download it from? I've seen it on "ReadTheDocs" website, but nothing official that I can find on Cisco.
Have you installed SDK Cobra egg files? Are you using Python 2.7 or 3?
Python 3 does not work. The whole thing works under Pyhton 2.7.
Wassim
Forum Tips: 1. Paste images inline - don't attach. 2. If you find a post helpful, please give it a thumbs up or mark it as a correct solution.
DiogoGoncalves23944
Community Member
I'm also having some trouble importing the acitoolkit module.
This is the error that I get:
  File "<stdin>", line 1, in <module>
  File "build\bdist.win-amd64\egg\acitoolkit\__init__.py", line 30, in <module>
  File "build\bdist.win-amd64\egg\acitoolkit\aciFaults.py", line 6, in <module>
  File "C:\Users\dfvieiragoncalves\code\py2-venv\lib\site-packages\jsonschema-3.2.0-py2.7.egg\jsonschema\__init__.py", line 33, in <module>
    import importlib_metadata as metadata
  File "C:\Users\dfvieiragoncalves\code\py2-venv\lib\site-packages\importlib_metadata-1.2.0-py2.7.egg\importlib_metadata\__init__.py", line 9, in <module>
    import zipp
  File "C:\Users\dfvieiragoncalves\code\py2-venv\lib\site-packages\zipp-0.6.0-py2.7.egg\zipp.py", line 12, in <module>
    import more_itertools
  File "build\bdist.win-amd64\egg\more_itertools\__init__.py", line 1, in <module>
  File "C:\Users\dfvieiragoncalves\code\py2-venv\lib\site-packages\more_itertools-8.0.2-py2.7.egg\more_itertools\more.py", line 460
    yield from iterable
SyntaxError: invalid syntax
I have the same problem
Following commands solved the problem:
pip2 uninstall more_itertools
pip2 install more_itertools==5.0.0
