APIC-EM - MPLS Site provision question
APIC-EM: APIC-EM-1.5.0.1368.
IWAN App: iwan-1.5.1.371
PnP App: pnp-app-1.5.1.35
I've being trying to setup a couple of branches with IWAN. APIC-EM is reachable from INET (static nat to the inside) and from the MPLS through BGP advertisement. The Branch with only INET link works flawlessly (NAT option used in APIC-EM), the problems start when the MPLS is in use.
Config:
*** Interface connecting to PE PPP
interface GigabitEthernet1
ip address 198.10.1.2 255.255.255.252
negotiation auto
*** BGP Peering with MPLS PE ***
router bgp 65003
bgp log-neighbor-changes
network 198.10.1.0 mask 255.255.255.252
neighbor 198.10.1.1 remote-as 600
Neighbor UP:
R31#show ip protocols
Routing Protocol is "bgp 65003"
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  IGP synchronization is disabled
  Automatic route summarization is disabled
  Neighbor(s):
    Address          FiltIn FiltOut DistIn DistOut Weight RouteMap
    198.10.1.1
  Maximum path: 1
  Routing Information Sources:
    Gateway         Distance      Last Update
    198.10.1.1            20      00:47:26
  Distance: external 20 internal 200 local 200
Log:
.Sep  1 13:29:23.392: %DUAL-5-NBRCHANGE: EIGRP-IPv4 400: Neighbor 192.168.66.2 (Tunnel10) is up: new adjacency
.Sep  1 13:29:36.494: %PIM-5-NBRCHG: neighbor 192.168.66.2 UP on interface Tunnel10
.Sep  1 13:29:36.495: %PIM-5-DRCHG: DR change from neighbor 192.168.66.3 to 192.168.66.2 on interface Tunnel10
.Sep  1 13:29:40.584: %CRYPTO-6-IKMP_NO_ID_CERT_ADDR_MATCH: (NOT ERROR BUT WARNING ONLY)ID of 172.16.12.254 (type 1) and certificate addr with
.Sep  1 13:29:43.518: %DUAL-5-NBRCHANGE: EIGRP-IPv4 400: Neighbor 192.168.66.1 (Tunnel10) is up: new adjacency
.Sep  1 13:29:46.785: %PIM-5-NBRCHG: neighbor 192.168.66.1 UP on interface Tunnel10
R31#
.Sep  1 13:31:14.011: %BGP-3-NOTIFICATION: sent to neighbor 198.10.1.1 4/0 (hold time expired) 0 bytes
.Sep  1 13:31:14.011: %BGP-5-NBR_RESET: Neighbor 198.10.1.1 reset (BGP Notification sent)
.Sep  1 13:31:14.012: %BGP-5-ADJCHANGE: neighbor 198.10.1.1 Down BGP Notification sent
.Sep  1 13:31:14.012: %BGP_SESSION-5-ADJCHANGE: neighbor 198.10.1.1 IPv4 Unicast topology base removed from session  BGP Notification sent
Configuration GigabitEthernet1 after IWAN changes:
bandwidth 300000
ip vrf forwarding IWAN-TRANSPORT-1
negotiation auto
end
This makes the BGP peering to be removed and IWAN setup fail.
I've tried a couple of options without success:
  • I've added the BGP into vrf after, but the PFR doesn't get used because the site still appears as failed in IWAN app and needs to be removed before it's added again.
  • Tried to create the vrf and BGP in vrf before IWAN deployment. It's fails since IWAN validates for existing vrf's.
Anyone can shed some light for possible solutions ?
Thank you
0 Replies 0
