PnP does not load config file to AP
jwiget
I'm trying to deploy AP over APIC-EM. I found some JSON file how to configure it.
The AP is able to connect to PNP but it stops if they should load the config file.
The failure on APIC-EM is:
2017-08-31 13:25:54 (Central Europe Daylight Time)Received response from pnp agent for message correlatorId: CiscoPnP-1.0-5-90-8BF17AC-4 but with error code : ZTD_CMD_ERROR Response String: BAD_PARAMETER:invalid cli command
At the AP CLI is waiting to receive the confg file, after a while the AP reboot because load of config file timed out.
*Mar  1 00:00:14.415: Starting Ethernet promiscuous mode
*Mar  1 00:00:14.419: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar  1 00:00:14.419: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...capwap_read_version_info: Info file flash:/ap3g2-k9w8-mx.153-3.JC7/info not find
*Mar  1 00:00:14.623: SCHED: Ethernet Bridge Process: install watched boolean System Initialized(43AD754), os:1 ah:0
*Mar  1 00:00:15.735: %LWAPP-4-CLIENTEVENTLOG: PnP waiting for capwap init
*Mar  1 00:00:15.735: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:16.467: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar  1 00:00:16.567: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2700 Software (AP3G2-RCVK9W8-M), Version 15.3(3)JF, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Tue 25-Jul-17 02:20 by prod_rel_team
*Mar  1 00:00:16.567: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:00:16.619: SCHED: Ethernet Bridge Process: remove watched boolean System Initialized(43AD754)
*Mar  1 00:00:16.623: SCHED: Ethernet Bridge Process: install watched queue Soap BVI input queue(43A1194), os:0 ah:0
*Mar  1 00:00:16.695: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar  1 00:00:16.695: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
*Mar  1 00:00:16.703: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - apEasyAdminConfig: there is no full image exists, continue anyway!
*Mar  1 00:00:16.703: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - Easy Admin is not enabled, turn it off!
*Mar  1 00:00:16.703: spamInitRadCfg: recovery image default mode 0
lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:16.867: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:17.623: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:21.491: DPAA Initialization Complete
*Mar  1 00:00:21.491: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar  1 00:00:22.491: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:24.491: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:00:25.491: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Mar  1 00:00:28.623: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar  1 00:00:29.623: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:29.695: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.37.224.20, mask 255.255.255.0, hostname AP54a2.7493.c7a8
bridge-group 1 source-learning
% Invalid input detected at '^' marker.
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar  1 00:00:35.439: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar  1 00:00:35.439: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
*Mar  1 00:00:35.443: %CAPWAP-3-EVENTLOG: No Config Present. PNP required
*Mar  1 00:00:35.443: Cert ISSUER (39): cn=Cisco Manufacturing CA SHA2,o=Cisco
%Error opening flash:/capwap-saved-config (No such file or directory)
%Error opening flash:/capwap-saved-config-bak (No such file or directory)creating PnP template view
Not in Bound state.
*Mar  1 00:00:54.047: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.37.224.20, mask 255.255.255.0, hostname AP54a2.7493.c7a8
*Mar  1 00:00:54.983: %PNP-6-HTTP_CONNECTING: PnP Discovery trying to connect to PnP server http://131.152.2.181:80/pnp/HELLO
*Mar  1 00:00:55.987: %PNP-6-HTTP_CONNECTED: PnP Discovery connected to PnP server http://131.152.2.181:80/pnp/HELLO
*Mar  1 00:00:56.991: %PNP-6-PROFILE_CONFIG: PnP Discovery profile pnp-zero-touch configured
*Aug 31 11:47:25.000: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:01:02 UTC Mon Mar 1 1993 to 11:47:25 UTC Thu Aug 31 2017, configured from console by console.
Aug 31 11:47:25.079: %PKI-4-NOCONFIGAUTOSAVE: Configuration was modified.  Issue "write memory" to save new IOS PKI configuration
Aug 31 11:47:37.011: %CDP_PD-4-POWER_OK: 15.4 W power - NEGOTIATED inline power source
Aug 31 11:47:39.011: %LINK-5-CHANGED: Interface GigabitEthernet1, changed state to administratively down
Aug 31 11:48:34.147: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
Aug 31 11:50:19.239: %LWAPP-4-CLIENTEVENTLOG: Timed out waiting on PNP config - Expect config from PNP server%No matching route to delete
This is my config file:
"primaryWlcIP":"10.33.6.2",
"apGroup":"standard"
It also not working, if only the primary WLC statement is in it.
What I'm doing wrong.
Thank's for help.
aradford
I think you are using version 1.5.0.211 of the PnP app.
I saw this exact issue with PnP on AP.
Upgrade the PnP app (it is now a separate package) to 1.5.1.35 and it will work.
The PnP app is only a 16M download.
Adam
aradford
Adam
Hi Adam
Thank's for your quick answer.
And you have right, with the PnP app 1.5.1.35 it works as expected.
Great, thank's
Jochen
