DEVICES WITH NO LINKS AFTER DISCOVERY -- CDP ENABLED --
sofianecirat
Hi everybody,
I hope someone would have an answer for me. I deployed the APIC-EM, and so far it's working fine, except that I'm  scratching my head over one thing. After,  performing many discoveries  (using both cdp, and range discovery), when I go to Topology, there are devices with no links,    ( 0 connections  ), even though, they have few  neighbors connected to them. So, in the map they are  just sitting by themselves, I thought aggregating them with their respective neighbors would create some type of dependency, but then quickly, I realized that I was wrong .  These devices have cdp enabled, and sh cdp neigh confirms it, I don't know if I'm doing something wrong with the discovery process, which is pretty straight forward, or what.....it's even affected the path trace app, because the trace goes nowhere from these devices, and it errors out with this message:
"Not able to locate unique interface or host for source ip address, Not able to locate unique interface or host for source ip address"
Below is just one of few  devices ( edge routers )  that have missing links ( no connection to their neighbors ),  which is killer to path trace
THANK YOU,
23 Replies 23
huajia
Level 5
Level 5
In my case, seems this issue happens after large amount devices discovered/imported. say about first 50-100 are good.
devices are 4331 (3.16.5) and 2960x (15.2.4E3).
APIC-EM is 1.4.
Exactly as in my case. First sites seem to work ok (about 60 devices) and after that all of the links are broken
huajia
Level 5
Level 5
after upgrading to 1.4.1.1159. today, few (between switches) missing links shown up. but the most are still missing if were missing before upgrade.
You might want to look at the Cisco Network Visibility Application for APIC-EM Supported Platforms, document. I found it helpful.
http://www.cisco.com/c/en/us/td/docs/cloud-systems-management/application-policy-infrastructure-controller-enterprise-mo…
Hi sofianecirat,
I read those  doc before. all version and devices are supported. CDP and LLDP are enabled.
also IPDT is on and snmp trap to APIC-EM. not sure whether should send syslog too and what level?
very interesting thing is the links (cdp neighbor) over DMVPN connection is also shown if cdp is enabled at both ends, but there is no link between devices within branch.
Vag
Any developments on this one?
Is there some kind of limitation of APIC-EM, where it can't support more than 50 devices?
For me, my hope is going to be to  upgrade the affected devices, with the recommended images.
aradford
no.  The scale is much higher than 50 devices.  You do need to be running supported software on the devices in order to discover them and have them show up in topology.
In my case, the devices that weren't forming links were in the supported devices' list: 2960X (15.0.2-EX5) and ISR2 2911 ( 15.2(4)M5).
Anyway, I found a workaround, which fixed the link connections:
I backed up APIC-EM, loaded the backup in a VMWare virtual machine and did a few changes, saved the backup and loaded it back to the physical server. This seems to have forced the link re-calculation.
Currently all of the links in the Topology work and about 60% of path traces.
