How to search devices using API
Bobby Stojceski
Level 4
Level 4
How can devices or items be searched for using the APIC-EM API? In PI I use the contains("search_string") method in the URL but I can't find an equivalent in APIC-EM's API. I tried using "=@" and "*=" and the same as PI in case it was the same function but none work.
So if I wanted to search/filter for any devices that start with the IP address "10.20.30.", how do I do that? Or if I wanted to search for part of a MAC address for example? Or maybe want to search for any network devices that have a hostname starting with "AU".
How is this done using APIC-EM API? Thank you
yawming
For example you you like know the device with certain IP address you can use
GET /network-device/ip-address/{ipAddress} API
This one is easier because there is an existing API, otherwise you can use
GET /network-device
to get all network devices then depends on the key you like to search,
for example "serialNumber": "FGL1548S2YF" or "macAddress": "68:bc:0c:63:4a:b0",or "hostname": "Branch-Router1"
you iterate the entire response from the GET query to find the device ID
for the device then use
GET /network-device/{id}
to get the detail of that device
Maybe there is other way but wonder if this can serve your need ?
Joe Clarke
You can also filter the results of, say, network-device:
https://apic-em/api/v1/network-device?managementIpAddress=10.20.30.
Properties like hostname, serialNumber and managementIpAddress can be used as query args.  They will then do begins with searches.  You can use '%' as a wildcard character to do contains searches:
https://apic-em/api/v1/network-device?managementIpAddress=%.20.%
